Cars & Trucks Logo
A
Anonymous Posted on Jan 29, 2016
My blackweb bluettooth speakers won't catch charge only had um for 3 days..worked fine til last nite.. wtf is goin on here?
rugby prop
Level 3:
Master:
  • Cars & Trucks Master 595 Answers
  • Posted on Jan 29, 2016
rugby prop
Level 3:
Master:
Answers
595
Questions
Helped
176536
Points
1670
I strongly suggest that you contact the seller of the speakers as they seam to be faulty.
2 Related Answers
Anonymous
  • 42 Answers
  • Posted on Sep 18, 2011
SOURCE: just changed oil two weeks
the gauge on the dash reads pressure from the engine, it kind of sounds like it has a oil pressure sending unit gone bad.there is a couple of ways to check this problem. first if you have a real manual gauge i call them. this has a tube that goes in place of your electrical gauge.they sell these manual gauges at parts stores and the fitting comes with it . when you install this it will give you a accurate reading on the pressure. this sending unit is behind the distributor.and a wires plug in on the top of the electrical unit. there is a socket that's for removal and installation they have these also at parts stores
skychief2001
Stephen
  • 21873 Answers
  • Posted on Sep 15, 2012
SOURCE: I own a 97 mercury villager an just won't start
I have a 98 model.
Someone will have to figure out if you are dealing with a no spark or no fuel problem when it won't start.
Could be a long list of causes depending on which issue.
Since it got freezing last nite & now it won't
If the engine will not turn over very fast,it is most likely your battery.Cold weather will kill a weak battery a lots of times.
I have a 98 model.
2answers
My 94 accord works well in the day, but jerks at nite
Have your charging system checked. It's likely that you have a bad diode inside your alternator, resulting in a partial charge. About the only difference between day and night driving is that at night you have your lights on (using more power) that may be depriving the ignition system of full voltage. How does it run in daytime if you turn the lights on?
Jetta won`t start
check alternator at auto parts also have battery tested.
2answers
96 ford taurus
ask previous owner...must have been the problem why he change it
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
