Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
The computer is not recognizing this as a hard ware
    President:
  • 1,383 Answers
Right click on my computer and go to property then go to hardware then device manager then uninstall all usb drivers then right click any then clik on scan for hardware changes then it automatic installe driver then restart computer then connect your harddisk to computer again then check .
Also check your usb cable is working fine.
Posted on Jul 15, 2009
HD-PNTU3 recognized as cdrom
No dont see it doing that cd/dvd and hard drives both seta and peta ares still all IDE devices so try to find it in your bios set up . but for "normal" install it should auto install the device firm ware and be visible in my computer as a removable mass storage devise
Sep 14, 2013 | Buffalo Technology Buffalo - Hdpnt500u3s -...
I have a 1999 VW Passat # 2 cylinder is not firing code 302 I replaced the coil pack,spark plugs and checked the wiring . I still have no spark on number 2 cylinder. Please Help
Hello you will now need to disconnect the engines battery using the proper sized wrench or socket.Ounce you have disconnect the battery for a couple of minutes now reconnect the battery this should reboot the engines computer keep in mind just like at home on your PC when you install new hard wear you must restart or reboot your computer for the hard drive to recognize the updates and hard ware.
Jan 02, 2011 | 1999 Volkswagen Passat
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Dvd Drive does not recognize any disks
Check if your DVD drive is showing under my computer. If not check it under device manager. If not listed there, possible Hard ware failure of your DVD drive. If it is listed on device manager but has error codes or driver issues, go to this link and follow instructions. http://support.microsoft.com/kb/929461
Hope this helps.
Dec 20, 2009 | Computers & Internet
My computer stopped recognizing my seagate
same thing happened with me, Looks like your pc usb slot is not providing enough power to the drive wither use a Y - USB cable (comes with three USB ends ; where in you will insert two USB cable ends to two usb ports on your pc and the other to ur hard disk) or buy a powered USB root hub.
Mash
Oct 18, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Hi. I have a Macbook 10.5.7 Leopard and a WD 320 gb hard drive. When I plug in the hard drive to my Macbook, it no longer recognizes, meaning the computer doesnt even recognize there is something plugged...
some things coming to my mind are
1) the hard drive doesnt have mac partitions
2)the hard drive is not correctly formatted
3)the rom chip on the pcb lost information
4) the drive corrupted one of its firm ware modules usually the ata module.
if you cant solve this problem pm me.
datarecoveryfactory.
Sep 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
High pitched noise, computer won't boot past sony screen
There is some hard ware problem for this physical site visit required.
Jun 01, 2009 | Sony VAIO Digital Studio PCV-RX670 PC...
Neextech usb external hard drive enclosure
ONE SHOULD BE MASTER AND ONE SHOULD BE SLAVE .
TRY IT AS SINGLE MASTER WITH SLAVE ON
DJUST THE JUMPER SETTINGS .... QWHEN YOU MAKE AHARD DISK SLAVE THERE SHOULD NORMALLY BE NO JUMBER IN ITS SLOT.
IF THE ABOVE DOESNT WORK
MAKE THE HARD DISK A USB HARD DRIVE .. YOU GET IT FROM A COMPUTER HARD WARE STORE
ITS LIKE AN EXTERNAL USB HARD DRIVE
IT WILL WORK IF YOU MAKE IT A USB DRIVE ...
Jul 28, 2008 | NexxTech Computers & Internet
Cruzier 4.0 pendrive is not recognized by my computer
the home computer has a small chip onits mother board called disk controller. its this controller which recognises it.so the software driver is corrupt and needs reinstallation or the hard ware controller is faulty.
Jun 09, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
203 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
David Payne
David Payne
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
