Question about Garden
The lawn mover start and after it heats up it stops working
  • 76 Answers
You should not let it get hot .
check the engine oil level you might missing some oil .
when did you last change the oil ? consider changing it .
Posted on Jul 15, 2009
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
Toro push mover starts then quits
Looks like a fuel problem. Remove fuel line from carb., should get fuel.
Nov 25, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Motor problem
Lawn mover quantum edge 6.5 will not stay started
May 23, 2013 | Garden
PTO WILL NOT CUT ON
I would check that you have a 12 volt supply down at the clutch when the pto switch is pulled out, if not you need to investigate the wireing and or micro switches,
Mar 13, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Oli spils when lawn mover starts
Check your oil level in the engine, normally if oil starts coming out of the air filter, it means you have too much oil in the crankcase. Drain your crankcase to make it the right level, be sure to check you oil level in the engine on level ground. I hope this helped, Good Luck Please rate me, Thanks
Dec 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Toro 6.5HP lawn mover it starts the it stops.
CHECK FOR WATER. DRAIN TANK AND REFILL MAY HAVE TO DRAIN CARB
Sep 24, 2009 | Toro Lawn Mower With Toro Power Tools
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
