Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
I couldn't figure out how to fax and receive faxes with my canon mf4350d. help! I did everything according to instruction. when I tried to send fax, it gives "error tx report" when I tried to send fax to myself, it doesn't work. I have only one phone line, therefore I set rx mode- fax/tel Since then I can't make a regular call from my phone, which linked to the fax machine.. But I can call from another phone in the other room, same phone line.
  • 1894 Answers
SOURCE: faxing
did u try to do a hard reset to clear this error?
if nt try it please
Posted on Jun 26, 2008
SOURCE: Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Posted on Sep 20, 2008
SOURCE: Canon Pixma MX700
I had the same problem. Solution? I will sound stupid, but it worked for me. Check every phone cable. Unplug and replug it. I solved my problem by making my connections simpler. I think, one of my splitter was faulty.
I still not understand why. I tried to fax without any phones plug-on and it was not working neither.
I'm with "videotron.ca" for my phone line and I unplugged the line from the modem too, then replug it. Maybe it was just that!
A lot of people seem to have this problem. I called Canon twice and they made me change some setting in my printer but their solutions was not working. I put all the setting back to what they was and it still working now.
Posted on Nov 20, 2008
rtrahan
  • 741 Answers
SOURCE: i want to fax over a regular phone line nota dedicated line
Yes you can do that..I have one at home myself on the phone line. As for as setting it up its all in your directions. There is no special equipment, you can call the phone company if you want they can make the ring different if its a fax versus a regular call..but that's the only thing you need to call them for...
Posted on Mar 20, 2009
SOURCE: Tx Cancelled: Rx Fax Info Mismatch
Can you tell me how you resolved it? Please Email me at:
PalpatineX@comcast.net
Posted on Dec 16, 2009
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
I CANNOT GET OR SEND FAXES ANYMORE. IVE TRIED
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 25, 2010 | Canon MX310 Office All-In-One Printer
My Canon MF4350d does not send faxes. All of the cords are connected properly. My phone that is connectedto my fax machine works fine, but I get no dial tone for my fax.
Does it dial the fax, but not send it? check which place you have the phone and line plugged into the fax machine. There are two plugs on the machine. One says line or wall, the other phone or handset. make sure the wall is plugged into the right one. that is the first thing to check, if not, reply and we can walk through setup.
Peace,
Mar 05, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
The fax answers each time the phone rings. If it's a fax then it's fine and it comes through. If it's a regular phone call then we can't really talk as the fax noises keep going off. We have a phone...
Your symptoms indicate that the machine is set in the "Fax Only" receive mode. If you are using the line for both fax and voice calls, you need to set the receive mode to "Fax/Tel". See Methods for Receiving Faxes in your Basic Manual for your options and how to set the desired mode.
Jan 27, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Hi my canon mx310 will not fax any ideas
disconnect all equipments using the phone line (everything)
connect the fax directly to a wall jack (a working one)
Send a one page black and white text fax to 1-888-473-2963
When your fax is received by the Test Fax Service, a return fax will be generated to you within five minutes confirming that fax was received. This verifies that you can both send and receive a fax with your fax machine.
Nov 25, 2008 | Canon MX310 Office All-In-One Printer
Comm. Error
Try this website: http://www.instruccionesweb.com/u2/pdf/fax/Canon-L120-en.pdf
Jun 25, 2007 | Canon L120 Fax Laser Printer
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
111 people viewed this question
old marine
old marine
