Question about HP Compaq Presario v3000z Notebook
I have got problem to external speaker pin its physically damaged..how can get a new one....
Tv static noise
You may have damaged the speakers physically. Try connecting an external audio system to see if the distortion follows it. That will be the defining answer here.
Jan 02, 2014 | Hitachi Televison & Video
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
Hi i have an LG 42PQ3000 i want to know if i can hook up external speakers to it as the is not setting on the menu i can find
Most new televisions will not allow to just hook up a speaker to them. You find Coaxial or optic audio outputs. These can only be hooked yup to a compatible external home theater system or soundbar. Most manufacturers today make wonderfull aftermarklet audio systems to help you enjoy the audio portion of a broadcast better. The amplifier in most new flat screens is not 10 watts, so driving an external speaker is out of the question. YOU WILL DAMAGE THE TV!
Jul 11, 2011 | Televison & Video
Poor sound quality
Many laptops have very small tinny sounding speakers built into them. If you wish to get better sound you can hook it up to a set of external speakers through the headphone port (or line out if it has it). You may also be able to get a set of USB powered external laptop speakers for your laptop.
You can check that there isn't dirt covering or stuck in the speaker grill, and that you don't have the volume too loud that it's overpowering the speakers.
Hope this helps, and thanks for using FixYa!
Jan 20, 2011 | Computers & Internet
Aspire 4930, Model no. JAL90 purchased on 31.3.2009.On 22.12.2010 suddenly display stopped working. What is the solution
Hello
The display of your laptop may go dark in one of two scenarios.
  • Physical damage that has resulted into a cracked or broken screen, if your laptop is dropped, especially with its case opened.
  • Malfunctioning of video power or control circuitry
If your laptop screen is physically damaged you should determined whether there is other damages to the laptop. You can plug an external monitor by using the video output connector to ascertain this. If your applications function of this external monitor you can simply go LCD screen repair and you can be sure that you will be able to recover your data. On the other hand, if there is no physical damage to your laptop screen and it goes blank you can connect to an external monitor and determine if other components of the laptop are functional. These steps will help you in your repair decision.
Good Luck
Jan 01, 2011 | Acer Aspire 4730-4947 Notebook
The channels are reversed. The red lead is the left channel whereas it should be the right. The leads to the cartridge match their color codes with the marking on the cartridge. The wires in the headshell...
If it a PROPER head-shell the leads DO come off the pins at the rear of the cartridge.
Also if you are using EXTERNAL speaker it may be that the speaker leads are incorrectly wired to the speakers and that would simply be a matter of swapping the external speaker outputs over.
Apr 05, 2010 | Crosley CR74 Turntable
Can't find radio fuse
please rate highly if this helps.
Visual Inspection Chart Mechanical Electrical
  • Integrated control panel (ICP) physically damaged, misaligned, any control(s) inoperative
  • Digital audio compact disc player physically damaged, misaligned, any control(s) inoperative
  • Antenna or antenna cable physically damaged, misaligned connection(s)
  • Radio speakers, mounting/speaker cones physically damaged, misaligned
  • Radio ignition interference capacitors, radio frequency interference suppression bond misaligned (also check for cleanliness and metal-to-metal contact)
  • Battery junction box (BJB) fuses F127 (5A), F117 (20A), F127 (5A).
  • Central junction box (CJB) fuse F227 (10A) F211 (15A), F216 (15A), F226 (10A) (wagon only)
battery box is under hood.
CJB is on left side of dash
May 10, 2009 | 2001 Ford Taurus
How do I wire up a external speaker to a Uniden SMG1525DT Radio?
pins 2 and 3 on the accessory connector are for an external speaker and pins 1 and 2 are for the internal speaker.
Nov 16, 2008 | Uniden SMH1525DT 2-Way Radio
HP Compaq Presario v3000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
