Heater won't fire
I have a kerosene heater that won't fire. I replaced the coil and some pump parts. It's getting fuel and spark and seems like it's trying to fire but just won't kick in all the way. Any help would be appreciated
  • 1 more comment
  • DueyD Nov 18, 2007
    It's a Reddy Heater 55 kerosene forced air.
  • DueyD Dec 21, 2007
    I have checked everything, plug gap, replaced the nozzle & fuel, checked pump gap, rotated the plug, cleaned the filter and it still won't fire
  • Anonymous Jan 20, 2008
    Same problem....Good spark lots of fuel...but will not light....sometimes it gets a little flame and acts like it wants to go but never does.
Place some kerosene into a small bowl, then place the fuel line drictly into the bowl . this way you can tell your getting good fuel. if no fire try removing the fuel filter. my filter was bad on mine i turned my upside down and it fixed it. its a in line filter.
Posted on Dec 23, 2008
  • 1,420 Answers
Not knowing what kind of heater you are trying to fix, lets look at the basics. Fuel, Ignition and Oxygen. You say you have fuel and spark, how about air? Too much fuel will not allow the unit to fire as well. Have you checked the fuel filter if there is one?
Posted on Nov 17, 2007
  • Chandler Ede
    Chandler Ede Nov 19, 2007
    Definetly check the fuel strainer and lubricate the fan motor. Filter Kit # HA3014, and replace your nozzle while you are inside. HA3021.
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
Jan 11, 2016 | Mr. Heater Heating & Cooling
I have a 35,000 btu Reddy heater that won't fire at the spark plug but is getting a signal from the magneto. Is the magneto bad or does the spark plug have to be in the mist of kerosene to spark?
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Mar 07, 2013 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
I have an older reddy heater pro 100 kerosene space heater,
You Must set the pump pressure quickly! If allowed to run with the nose cone a "bright" cherry red the welds will deterioate to the point that the end will separate from the combustion chamber. Individual sheet metal parts of the chamber are not available.
Learn how to properly set the air pump pressure
Feb 25, 2009 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy heater runs then stops
it's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Garage Heater
the kerosine heater uses a spark plug for ignition and a photocell to detect flame. at the back end of the blower motor is an air compressor. it is a vane and diaphragm compressor that supposed to put out 3.6 psi of air to the fuel nozzle. the fuel nozzle is a venturi type that creates a vacuum across the orifice to suck fuel from the tank. try this site for spare parts www dot desatech dot com. its the same place I get parts for repairing heaters.
Nov 29, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
Heating & Cooling Logo
369 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
