Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
My router (DLINK WBR2310) is not emitting the wireless signal (light not blinking). All other functions working properly - no problem with modem or connections. It is picking up the internet etc, from modem but the wireless symbol button is not lit. Is my router fried? we have tried resetting etc. please help? thanks!
  • jlancio2 Jul 16, 2009
    thanks but this really didn't answer the question. if the light in question is out, but all the others are on, can i assume the router is damaged? all other lights and connections are fine - so my question is what does this mean?
    Okay that helps clarify thanks. one more question - what does this mean exactly?
    "NOTE: Upgrading the Firmware may hard reset your router and you might loose all the configuration"
    Thank you.
  • 813 Answers
Try to upgrade your Firmware version from:
http://www.dlink.com/products/default.aspx?pid=WBR-2310&tab=3
It shall ask you to choose the model number of router from WBR-2310 or WBR-2310_REVB Select your model from the above two. There is also a link that says How do I determine the hardware revision of my product?Read in case you do not know the hardware version of your Router. After selecting the correct hardware, click on Firmware and download the latest firmware for your router. Open the admin console of your router and select to update your Firmware. Select the updated firmware file from your computer. Wait till the update is finished. Reboot the router for changes to take effect and then check.
NOTE: Upgrading the Firmware may hard reset your router and you might loose all the configuration.
Posted on Jul 15, 2009
  • Dixit Sardana
    Dixit Sardana Jul 16, 2009
    It seems that the wireless radio of your Router is not turning On, despite being configured it to turn On. It can be due to some hardware failure or the Firmware of your router getting damaged. Your router doesnot seem to have any kind of hardware failure as other functions are working fine. So we can upgrade your Firmware so that it resets the hardware to factory defaults. Moreover having an up to date firmware also resolves many of the known issues and bugs with the hardware and/or software.
  • Dixit Sardana
    "NOTE: Upgrading the Firmware may hard reset your router and you might loose all the configuration." means that you will loose the configuration settings (IP addresses, pppoe settings, your phone number, username and /or password and the name of your wireless network - also known as SSID)
I went through the set up wizard with my dlink DIR-850l and it said successfully set up but the orange internet light on the router is still blinking and i cant figure out how to properly connect it. i...
You are not getting a signal from the modem. Check which port you put the modem ethernet into and make sure you're able to get on the internet directly from the modem.
Sep 19, 2013 | D-Link Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
Keeps saying mismatched password wont connect DLink WBR2310
the password was wrong just reset the modem and reconfigure once again other wise in the address bar type the default gateway its ask for user name and password just enter the user name and password you can find the user name and password at the manual of your router it will login to your modem page in that you can find the option called security in that security you can find your old password
Thank you
Jul 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link WBR2310 router won't work with Belkin modem
Hi kinobe. You have to check when you connect your computer to one of the ports on the back of the router you get a light on the front of the router. If you dont get anything on any port (even when you connect the modem to the internet/WAN port - that means that one "transistor" inside of the router it's bad. So you have to open it and fix it (but that's electronic repair and you need to have the proper skills and get the exact transistor). There's a posibility you can still connect to the router wirelessly because that's another circuit in the router but If you dont get signal from the modem to the router it's pointless so you have to replace the router. I hope this helps and don't forget to rate and write positive feedback for our fast - free support today. Thank you :D
Apr 29, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I lost the installation cd where can I get a copy?
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 23, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless network gets disconnected
i believe it supposed to be
modem--> vonage -->router
-->phone
Jul 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Dlink hooked up but modem acting like router
I did that once, left it like that for about 3 months till I was bored and decided to mess with it. I then remembered It had a Reset button. Press that and everything should be back to narmal.
Feb 01, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
WBR-2310 DLINK router is not showing in my wireless network list
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Nov 27, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
122 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
