Question about Refrigerators
Refrigertor not cooling but freezer working
Refrigertor portion not cooling food but freezer portion freezing food as normal. This is a Montgomery WARD 17 Frostless, Energy Saver, about 24 years old.
  • 534 Answers
Your temp control fan has probibly gone out. The way you find out is to find the fan which should be located near the temp control switch behind a plastic vent. If this fan is out there will be cooling in the freezer but not in the fridge. Also, if you open that area and find a large chunk of ice you defroster rod has gone out. Would recommedn replacing both at that time. Get model and serial number of unit and take to an appliance parts house they can assist you in the right part and any type of installation problems. Good Luck
Posted on Jul 15, 2009
Frigadare refrigertor side by side its cooling fine but the freezer wont freeze
Check the heater coil in rear of freezer. Mine was burned out. Letting ice build up on the cooling fins. Replaced with new type double heater coil and fixed proble. You'll have to remove the cover off rear wall of freezer section to access it.
Jul 04, 2014 | GE GSS20IEP Side by Side Refrigerator
Refrigerator is not cooling
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Refrigerators
Refrigertor not working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Hotpoint HSS25GFP Side by Side...
I have a kenmore refrigertor and it's not stay cool at all. what
when you say not cool is the freezer freezing or the refrigerator not cold
Apr 07, 2009 | Kenmore 57029 Side by Side Refrigerator
trying to rechange my avanti mini refrigertor but i dont know where it goes please help me
Nov 28, 2007 | Avanti FF1101W Top Freezer Refrigerator
Food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
Nov 19, 2007 | KitchenAid KSRP22FNSS Side by Side...
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
