Problem with the VISIO tv Mod E422VA Led on front blinks 23 times and the stays on.
Pulled the back off and found that there is no 12v. There is 5v. Checked the fuses on the control board and they checked good. The Power supply board # 9QG2LAAW.
Do you know the the blinking led means?
Have tried this a number of time and it does not correct the problem. I have also replaced the Power Supply and that did not fix the problem. I have unplugged each of the boards and did not see a change.Have tried this a number of time and it does not correct the problem. I have also replaced the Power Supply and that did not fix the problem. I have unplugged each of the boards and did not see a change.
You can't post conmments that contain an email address.
try taking batteries out of remote then unplug tv then plug back in then put batteries back in remote then try to turn on with button on bottom back left side of tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result 1 I2C1 2 I2C2 3 I2C3 4 I2C4 5 VIPER 6 5V supply 7 8V6 supply 8 1.2V DC/DC 11 3.3V DC/DC 12 12V supply 14 Supply Class D amplifiers 14 Supply Audio part SSB 17 MPIF1 audio supply 18 MPIF1 ref freq 25 Supply fault 27 Phoenix 28 MOP 29 AVIP1 31 AVIP2 32 MPIF1 34 Tuner1 37 Channel decoder 39 POD Interface 43 Hi Rate Front End 44 Main NVM 45 Columbus 53 VIPER 63 PDP Display
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
