Question about Whirlpool ED5FTGX Side by Side Refrigerator
The deforst timer didn't work and got ice
I have a whirlpool refrigetor and the deforst timer did not work. When the ice build up, it runs all the time
    Champion:
  • 287 Answers
Does the timer move? If you can, try rotating the timer to the defrost postion when the frigorator turns off and see if the defrost emement starts to heat up. If it doesn't then you could have a bad thermostate. easy to replace.
Posted on Jul 16, 2009
Hi,my GE refrigerator have alot of ice in the frezer comparment hoy can i fix? Refrigetor side not cold. Thanks
First off,
Ice build-up in the freezer compartment is an indicator that the defrost system is not working properly.
The defrost system is composed of the defrost heater and the defrost thermostat. If one of them is not working, ice will build up in the freezer compartment.
You need to do a continuity test on the defrost heater and if it is good, very likely the culprit is the defrost thermostat. Just replace the thermostat
Aug 02, 2017 | GE Refrigerators
Hi, I have subzero side by side refrigetor. Building up on back panel on refrigetor side . I defrost it clean and in week again ice building up ? Ho to resolve ? Thanks
check aall your seals on your doors and make sure they are sealing tight. Your compressor is working extra hard and freezing up. Also check the thermostat and make sure its not turned down to low, that will also cause compressor to run hard
Oct 09, 2015 | Refrigerators
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
Freezer is cold but fridge is hot.is there a timer to defroze timer can it be faulty.need your help from ram.
try to check your evaporator fan if working. replace it if defective try it defrost manually then observe or check defrost timer and defrost heater rotate deforst tmer by your hand possible stock up thes thing you do if it is a build up ice in the freezer.
Feb 27, 2011 | Ariston Technologies Refrigerators
Hai this is arun from oman.. i want to know how to
Check the defrost timer is operating and that the defrost heat element is working, usual cause of ice build up in most units, you may want to get an electrician to do it coz one wrong move it WILL kill you. Good luck.
Dec 18, 2010 | Desmond 49 cu. ft. / 1388 liter Commercial...
Why is the freezer part working and the main fridge part is warm?
hi deforst element or timer may not be working look frost in freezer. i would check timer frist. hope that help
Oct 10, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Whirlpool Refrigetor's copmressor is continuesly on , what is solution , is there is problem with thermostat
Yes since your compressor is running continuosly the first case of the fault could be the thermostat. So you might have to trace the wires to the thermostat including the bimetal / sensor. Check for breaks in the wires as due to frost build up the wires may disintegrate in due time. If not you will have to go with confirming the thermostat. Hope your fridge is working fine otherwise and you have not noticed any other anomalies because if the compressor runs continuosly the cooling can also drop which will therby make a chain reaction for not lettting the thermostat reach the temperature. So inthis case the timer could also be a suspect. So please check all these factors. Good day
Aug 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Wirlpool refrigetor model ed2chqxkl05
try these tips. http://www.hometips.com/home_probsolver/hps03/09_refrig/hps_refrig09.html
Aug 23, 2008 | Whirlpool GD2SHGX Refrigerator
Whirlpool ED5FTGX Side by Side Refrigerator Logo
98 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
