Question about Roketa 150cc cheap Scooters
Roketa Bali 150 not charging
I have a Roketa Bali 150cc scooter. I changed out my start button A and then I started it and noticed the ammeter read 9 and when I rev it up the ammeter may go up to 10 it does not seem to be charging the turn signals go on but do not flash the brake lights do not go and the headlight is very dim. Before I changed the button the ammeter would read 12 and when I ran it would read 13 so I don't think it is charging Can you help?
    Top Expert:
  • Roketa Master
  • 40,028 Answers
Hi, Brucep63 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test:
Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
5. Stator Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity your stator is shorted to ground and must be replaced.
6. Regulator Test:
Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test:
This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Roketa Bali 250 Battery not charging
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.roketapartsdept.com/
Roketa bali 150 Owner Manual
Posted on Jul 05, 2017
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: 150CC Roketa Scooter
Hi and welcome to FixYa,
On most versions of Roketa 150cc engines, the choke is automatic and electrically driven..  It is integrated with the carburetor.
Good luck and thank you for asking FixYa.
Posted on Jun 29, 2009
plaztiksr4me
  • 154 Answers
SOURCE: Chinese Motorscooter Rear Disc Brake Dragging Roketa Bali 150cc.
sorry if its japanese there kits are over there unless you know someone that can speak it i dont know how to find one i would check ebay or amazon.com other than thet you gotta put out the dough.
Posted on Apr 23, 2010
The six pin plug from the bike shows all pins shorted to ground. This on the headlights. I have a 2008 Roketa 250. Also I cannot switch from lo to hi.
Hi, David for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Roketa, despair not, for a mere zero $0 you can download another one.
Honda CN250 Owner Manual
http://store.oohla.com/storefiles/terminatorscooter//download/accessory/2658/sms.pdf
MC54
ROKETA atv exercise fitness dune buggies scooter gokart dirtbike moped...
Roketa Scooters
Apr 18, 2017 | Roketa 150cc cheap Scooters
I had my 06 gy6 roketa 150cc scooter running good,shut it off n now can't get no fire...wont start...new carb,new plug! Any help?
Hi, Jim and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
engine cranks spark but still no start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
MC04A1501
Mar 29, 2017 | Roketa 150cc cheap Scooters
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
How do you remove the gas tank on a 2005 roketa bali 150cc scooter
Hi Anonymous, for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Sep 11, 2015 | GAS Motorcycles
Roketa 150cc scooter wont start
check for spark. the stater tends to burn up in thows bikes.
Jan 27, 2013 | Motorcycles
My 150 cc motor scooter won't start
possible choke stuck or a sticking float
Jul 29, 2012 | Roketa 150cc cheap Scooters
Gear oil change MD150t-6
i didn't got your question, what do you mean by Gear oil change MD150t-6 what do you want to ask.
[url=http://www.scootercity.co.uk/]moped[/url]
Jun 23, 2012 | Roketa 150cc cheap Scooters
Jul 30, 2009 | 2008 Keeway Matrix 150
Jun 29, 2009 | Suzuki VL 800 Volusia Motorcycles
Roketa 150cc cheap Scooters Logo
185 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
