Attempts to start but closes immediately - Computers & Internet
AO error code on 250k btu hayward pool heater
Dear ,
Please try the below solutions,
Solution 1:
If the blower prover switch does not close after the blower starts the control will stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes
Solution 2:
If the blower prover switch opens unexpectedly during operation the control will shut down and attempt to re-light. If the switch does not close after the blower starts the control will go into lockout with the blower running. Automatic reset is immediate after error is corrected
Solution 3:
If the blower prover switch opens during the postpurge cycle (heater is not fir- ing) the control will display the error code. The post-purge cycle will be com- pleted once the blower prover switch close
Regards,
Samy
Aug 10, 2014 | Hayward Pool & Spa
03 Beetle fuel pump runs even after ignition is turned off. Also when cranking will fire then die immediately. Raw gas coming out of tail pipe after several attempts to start
FUEL PUMP RELAY FAULTY.FLOODING OUT THE ENGINE.FUEL PUMP RELAY REMAINING CLOSED ENERGIZED CAUSING FUEL PUMP TO RUN WITH THE ENGINE OFF.
Sep 25, 2011 | Volkswagen Beetle Cars & Trucks
CONTACTOR RELAYCLOSE BUT LOOK BURNED , FAN MOTOR START , BUT COMPRESSOR MOTOR START AND STOP IMMEDIATELY. CONTACTOR STAY CLOSE BUT COMPRESSOR DON'T RUN.OR COME ON AND STOP IMMEDIATELY.
sounds like a locked rotor, did the compressor get hot? did you check max amps on the compressor when it attempted to start?compressors have thermal protection built into their windings, a switch that will open to protect the compressor, and if the rotor is locked, normally you have to replace it, you could try putting what is called a start assist capacitor on it (AKA hard start kit) I would recommend the two wire model, easy to install.
You will need to wait for the thermal overload to reset, turn power off to unit till you get the kit on there.
Jul 18, 2011 | Heating & Cooling
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Car starts fine initially but if I turn it off and retstart it it's dead. No clicking to attempt to turn over. This has been going on for 3 days. However If I take the fuse out for the starter and put it...
I don't think it is a major problem more likely a problem with the fuse not making contact,make sure that both the contacts where the fuse goes are close enough together to make good contact,you might have to squeeze them together a little....hope this helps....cheers
Jun 24, 2010 | 1996 Pontiac Grand Prix
Error AO ON MY HAYWORD H SERIES POOL HEATER
The AO mindicates an open prover switch ,, here from Hawward site .
immediate after error is corrected.
reset is immediate after the switch closes.
May 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
LG V271 DVD VCR Combo problem
try cleaning the player. with a dvd clean disk..for about $5.00 to $7.00.... and wipe down the player.
sometimes dust and trash gets in the way and will not close properly and you end up closing an closing until the trash get out of the way... cleaning it will help..
Apr 14, 2009 | Sharp DVRW250 DVD Players
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
