Question about HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive
Receiver seems not working
When mouse and keyboard wireless receiver pluged in to the base or laptop receiver is not workikg.I can hear sound of plug in but after sound of lug out.expansion base is working I can hear music and work with volume.When receiver pluget in to diferent comp light on receiver is on but can not conect muse or keyboard.
Thank you.
Re: receiver seems not working - HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive Hard Drives
Same problem - 0 support from HP
Posted on Jun 13, 2008
I'm pretty well sold that the technical support at HP is completely worthless. They have some tree they look at for answers but have no actual technical ability, making them about as useful as an extra **** on your elbow
Posted on May 20, 2008
0 characters
3 Points
How do I watch movies off hard drive on my Sony kdl32v4000
The problem is the multitude of methods of encoding video.
Most graphic images are in .png, .jpg (or similar) so TVs will decode those types from cameras with little difficulty.
A hardware based A/V decoder ($$$) for each video and audio type or software and a CPU $$$ would be needed for the TV - thus driving the cost of the TV higher still. The best way to do it is with a HTPC or Home Theater PC (computer). This is just a PC with: 1) enough processor power to decode HD Video in real time (think: a 64 bit or dual core or better CPU), 2) an HDMI output jack, 3) wireless keyboard 4) wireless mouse, 5) USB port(s) and 6) network connection.
Connect the HDMI cable between your PC and the TV (or Stereo that sends video to the TV and plays audio thru your Dolby Digital sound system) and use it like a regular computer with a huge HD screen from your couch. You can quickly navigate Netflix and other online content including the internet without the need of seaching & scrolling around for letters one at a time via onscreen keyboard - just type away on your keyboard instead - FAST!
Oct 23, 2015 | Sony Hard Drives
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
I have 3 maxtor 3200 storage units. A few days ago my computer would not start up so after unpluging the 3200 and everything else I got the computer to work again. Plugging in the mouse,keyboard,zip drive...
could be a software issue could be that the when you unpluged them you didnt unmount the drives from the system and now windows is not finding them for this reason the best way to "try" to fix this issue is to plug them in one at a time go into device manager and uninstall them from the computer then turn the computer off unplug the drive turn the computer back on without the unit pluged in turn the computer off again plug the unit in restart the computer this will work on 75% of the drives that can't be seen
Jan 25, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
O/s will not recognise keyboard/mouse
maybe it did not recognize it because the system has not yet installed the drivers or maybe the keyboard and mouse is faulty.
Get an external keyboard, as this will help to know where the problem is coming from.
I wish you all the best.
Jan 07, 2010 | HP Xb3000 Notebook Expansion Base And...
Touchpad pointer moves by itself. Moves slowly to either the top right hand corner or the bottom left hand corner.
Sounds like their might be some dirt underneath the surface of the trackpad exerting pressure causing it to move. Try turning down the sensitivity, do this under mouse in Control Panel.
Jul 29, 2009 | CMS Products - 160GB 5400RPM HD DELL...
If the cursor doesn't move - and the Accupoint mouse is part of the keyboard - then simply replace the keyboard. Remove the plastic strip in front of the keyboard, one screw that hold the bottom of the keyboard down, and the rest is obvious.
Dec 13, 2008 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
It won't recognize the keyboard
I tried forever to connect the keyboard & mouse, then realized that I didn't have to hold the connect buttons on the receiver & keyboard for so just wouldn't connect...until I figured out that you should only press the buttons for a second then immediately let go...both keyboard & mouse (while both cheap looking) have been working great since! Love the hot-buttons/keys!
Feb 05, 2008 | HP Xb3000 Notebook Expansion Base And...
Hubs don't work on LaCie minin 250 GB Hard Drive
there is not enough power coming through ports each device re-quires 1-5 volts to run and if your mac has not got enough power to boot all devices then sadly all things pluged into will not reconise and with mac the os is not properly designed for it now if you got yourself an external usb 2.0 hub powered then yes all devices will be seen in mac windows firewire is unsafe at moment for this to happen ask them what system they had had configuration on. hope this has helped
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
HP Xb3000 Notebook Expansion Base And 400gb Kit 400 GB Hard Drive Logo
526 people viewed this question
Top HP Hard Drives Experts
john smith
 Mike M
Mike M
Are you a HP Hard Drive Expert? Answer questions, earn points and help others
