Question about Refrigerators
No ice there is no ice being made and no water in the feed tray ...I put a new PUR filter in but still no ice...the water dispenser does work
    Problem Solver:
  • 16 Answers
Three possible causes:
1. The saddle needle valve on the supply line - (your plumbing) - has finally clogged up entirely from a gradual calcium build-up. This happens quite frequently. Close the main valve on your water plumbing, remove the saddle needle valve, and check for blockage. If blocked, try to clean it out. However I would recommend simply replacing it with a new needle valve which can be purchased at any hardware store for just a few dollars.
2.. The control module in the icemaker is malfunctioning. If so, a replacement module can be purchased and installed. However, given the cost of that module, I would recommend simply replacing the entire icemaker unit for just a few dollars more than the module cost.
2. The water fill valve, located near the bottom rear of the refrigerator - (on most models) - is either malfunctioning or its screen filter is totally blocked. In either event, that water fill valve should be replaced. The replacement cost of a water fill valve is relatively modest.
Posted on Jul 15, 2009
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
Problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Apr 30, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
The water solinoid is not sending water to my ice tray
Had the same problem. As long as the ice machine is still moving, meaning its working but just no water is getting to the ice tray.  order part #2205762 valve, solenoid and change it out.  It is not hard to do if you pay attention to how you take the old one out.
Feb 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
