Question about Maytag Washing Machines
I need control panel diagrams which have peeled off in heat!
I have a Maytag Washer Model A209 and matching electric dryer. They have been in storage a long time in the heat of Las Vegas.
How do I find a diagram of the control panels?
The paint on the control panels is peeling off and I cannot see the settings anymore.
Once found I can use a sharpy to mark the settings or use a label maker.
All help will be appreciated.
THANK YOU!
A
  • 441 Answers
Go to maytag.com under the service heading you will be able to print up a copy of your owners manuel, that will show you the dial
Posted on Jul 15, 2009
De 407 maytag dryer how do i find a wiring diagram
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Jul 03, 2014 | Frigidaire GLER341A Electric Dryer
Need a wiring diagram
Most appliances have a wiring diagram inside them. (I know washers, dryers, and fridges do). Have you checked to see if there is one? Usually they are printed on green paper and folded up. Obviously for an oven, they'd have to be away from the heat source. Maybe near the control panel on the back, or if there is a storage drawer on the bottom of the stove, it might be in there, or taped to the back of the drawer.
Apr 08, 2013 | Maytag MER7662WQ - 30"Self-Cleaning...
Maytag LSG 7806 Electric Dryer doesn't heat up how can I get a wiring diagram
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 30, 2010 | Maytag LSG7806A Front Load Stacked Washer...
My dryer will not heat up. What can I try at home before calling a repair person? It is a glass door dryer that matches the Maytag front-loader washer.
pull the vent hose off and turn the dryer on and see if there is hot air coming out, if not then it is the heating coil
Aug 12, 2010 | Maytag EPICz Electric Dryer
Need color code wire diagram for control wires on timer switch. model#pye2300ayw maytag dryer
This info should be located behind the control panel of your dryer. If not, someone must have removed, try asking again if it's gone.
Oct 19, 2009 | Frigidaire GLER341A Electric Dryer
How do i replace a belt on a maytag washer model a209
unplug washer, tip backward 45 degree against wall, motor is spring loaded so push motor to get slack to replace belts
Aug 18, 2009 | Maytag Washing Machines
Maytag proforma gas dryer no heat
The model says electric and is listed as gas. If it is electric. Move all the settings (exercise the controls) If that does not work Turn both of the breakers off at your electric panel and back on. If one feels loose you know it may have tripped and you just reset it. Your drier will work fine now. Just turn it on.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Dryer takes a long time to warm up. It drys in 2 hours and does not shut off automatically. Maytag series 200
To make things properly, voltages to heating element should be tested, but that is a job that must be done by a technician.
Test first the heating fan. If it is not working replace the fan assembly.
Replace the heating element if that does not solve the problem replace the control board.
You can find schematics and diagrams by entering model number here.
Feb 18, 2009 | Maytag PYE2300AY Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
