Front door does not open after washon model wm 12x
Front door does not open after wash on model wm 12.
Door handle seems very "slack". How do you get the door off to check the handle mechanism?
  • 92 Answers
Firstly unplug the appliance,then take top off then with you hand reach down towards the door mechanism on the inside then feel for a lever or the cable and play around with that and the door will spring open,then check the door handle
Posted on Jul 15, 2009
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
Door handles slack feels like springs dropped so cant open door
You can release the catch from inside just keep trying and thern you need to replace the door catch itself this is a simple job
Jun 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Lgwm2277h front door problem
The latch on the door had to be change
Sep 16, 2008 | LG WM-2277HW Front Load Washer
Washer door latch
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
Jun 24, 2008 | LG WM-1832C Front Load Washer
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
