Question about Samsung Computers & Internet
My Samsung monitors power button flashes real fast but wont turn on
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 17, 2009
Tip
Shut Down Your iPad For Real
When you press the power button on the <b>iPad</b> actually turns off just the monitor. That's why we talk so fast. What can be done to conserve battery power, or to recover from the freeze is to reboot the system. To do this simply by holding both the power button and the Home button until the red slider appears. Press and turn the <b>iPad</b>. Give it a minute and you can reboot by pressing the power button. It seems that a few seconds before responding so be patient.
on Dec 15, 2010 | Cell Phones
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Nothing will display on the monitor. Power button
More likely to be bad capacitors (bulging top/seal) in the power supply, that will be the first palce to start, post back what you see inside so we can guide you further (it can also be bad inverter circuits, main power supply, etc), see example of failed Samsung monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Acer AL1916B 19" LCD Monitor
Samsung lcd monitor power button flashes and wont turn on or off
I have the same exact problem. The monitor seemed fine yesterday. Today, the power button light just flashes on and off, with nothing on the display.
Dec 05, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
My samsung syncmaster 2232bw wont turn on at all, and the pilot light(blue light surrounding power button) is flashing repeatedly at a fast pace, much much faster than the norm?????????
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Dec 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
1of 2 monitors wont turn on
Frostbane is correct. I called 1-800-SAMSUNG to report the same problem and they are going to send me a replacement display.
Mar 24, 2009 | Samsung 226BW Monitor
Rca 53" wont power on, please help
The cicuit board behind the power on and off button needs to be replaced.. good luck everyone
Jan 07, 2009 | RCA D52W19 52" Rear Projection Television
Computers & Internet Logo
271 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
