I have a older Singer unit (Heat & Air) built into my wall, I cannot find a filter to clean. The unit has started dripping water on my floor. Margaret Averre 2819 NW Lynn CIr Lawton, OK
  • maggie1705 Jul 15, 2009
    We cannot find a way to remove the cover, there is some screws on bottom of unit, this unit has been in wall for several years floor is concrete, I don't think the floor has shifted, the outside part of the unit only extends about 3" from the wall, will the drain be on underneath of this part
    I'm not sure but will see if it works when I get home today.
  • 441 Answers
The filter should be located behind the front panel but if your getting water back in the house than it is one of 2 things. 1) it is not leveled propery, the unit needs to tip slightly to the outside so it can drain, Or 2) the drain tube is clogged, lots of older unit have this issue. I would start by taking off the front of thu unit and looking to see if the bottom pan is full of water, you might be able to just tip it a little bit back and fix it. Make sure that you unplug it before you start!!
Posted on Jul 15, 2009
  • John Riley Jul 15, 2009
    When looking at it from the outside look at the bottom of the case, the drain will just look like a small 1/4" hole in the corner of the case, see if anything has plugged it up. As far as the front panel goes if you cant find any screws some of them just have spring clips that hold on the cover
Hi, recently my a/c window unit starting making a water sloushing sound then started spitting ice. Is it dying?
What you are hearing is a water buildup in the drip pan under the unit. This is caused by a clogged drain hole and/or not enough downward tilt on the rear of the unit. The rule of thumb is 1/4" to 1/2' rear downward tilt. This allows the water to flow to the rear of the drip pan and out thru the drain hole. The spitting ice, is from the fan blades hitting the water in the drip pan. Turn the unit OFF & unplug it. Then check and adjust if necessary, the things I mentioned above. Aslo, be sure that the air intake filter remains clean.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Maytag M7D24E7A Air Conditioner
The Dehumidfier runs but it is not collecting water. If the unit is tipped forward it will drip water. It was working well until recently.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 25, 2011 | LG Dehumidifiers
The unit starts to drip water inside the house down the wall of the window that it is in
What you will need to do is reposition the window unit to where it is slightly tilted downwards in the rear so that the water flows out the backside.
Jul 06, 2011 | LG Goldstar GWHD5000 wall/window Air...
My dehumidifier runs but no water drips in the pan
Clay, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If your unit does not have an
LED screen, turn the manual control to Maximum.
level
problem.
Hope this helped you to troubleshoot & solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Heat Controller BHD651 Dehumidifier
The unit ices up after an hour or so and then water runs down the wall and not into the drip tray
Two issues are possible.
First of all check for dirt accumulation that is blocking the water to drip but is diverting to the front panel section to flow into the wall.
Secondly the A/C must be mounted with a slight tilt thereby making the water condensation to flow/drop into the tray. If not you can remove and make a small wedge on the mounting to tilt.
Also use a good air jet or a water jet( if taken out) to clean the coils.
Jan 05, 2011 | Frigidaire FAA065M7A Air Conditioner
Water is backing up and dripping out of wall unit. I've checked drainage pipe and its clear. water is not getting into drainage pipe in unit.
The water dripping from evapourator is due to clogging of the cooling pins.where in the condensed water logs into the front portion into the filter,the front pannel and to the wall.If the unit is slightly tilted, this would be reduced.use a good brush and air pressure to clean the fins.If periodical cleaning of the filter is not done,this can happen.
Sep 02, 2010 | Heating & Cooling
What could be wrong with my aircon unit? Water dripping sound
Your coils need cleaned, and change the filter too. make sure drain is not cloged also.
Jul 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Frigidare thru-wall AC drips water when unit is on.
Do not try to drill any holes but search for the built in drain and open it. Again do not use a drill. Get a shop vac.
Jun 09, 2009 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
