Question about Dryers
No hot air
The dryer was run with the lint catch full, now it is not making hot air, it is a maytag, aprox 20yrs old, model DE 312, series 07, serial # 163305 BF
  • felcocontrac Jul 15, 2009
    can someone tell me if this unit does in fact have a thermal fuse
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 15, 2009
Have a maytag heavy duty dryer model lde512 07 series and it is not getting clothes all the way dry what could be wrong
Problem might be with your washer not spinning them dry enough..or your vent is plugged up with lint
May 06, 2017 | Maytag Dryers
How do you wire the dryer MDE300AYW
Instructions
    • 1 Remove the lint screen from the dryer. If you are unsure how to remove the lint trap, refer to your owner's manual, as removal directions vary among Maytag models.
    • 2 Use your fingers to remove large chunks of lint from the lint screen. You should remove the lint from the lint trap after every load.
    • 3 Run the lint screen under the faucet. Use hot water and thoroughly wet down both sides.
    • 4 Scrub both sides of the lint screen with a wet nylon scrub brush. Rinse the screen again under hot water to remove loosened buildup. Allow the lint screen to air-dry on a towel before putting it back inside of the dryer.
    • 5 Make a paste of powdered laundry soap and warm water into a small bowl. Use three parts powdered detergent to one part water. Stir with a spoon until a paste forms.
    • 6 Dip a soft rag into the paste. Wipe down the entire interior of the dirty Maytag dryer with the rag and paste. Apply more paste to the cloth as needed.
    • 7 Rinse the interior of the dryer with a damp rag to remove the paste.
    • 8 Dry a load of damp towels in the Maytag dryer. Run a complete dry cycle to remove any residue left inside.
    • 9 Wipe down the exterior of the dryer with a rag moistened with all-purpose household cleaner. You can also use the household cleaner to remove certain stains from the interior of the dryer. Make sure the cleaner you are using is noninflammable.
Jan 15, 2013 | Maytag Dryers
Dryer not heating. It's a Maytag LDE 312 Series 7 dryer.
Check out the entire venting exhaust tubes for lint build up. A moister sensor will detect any lint build up and keep the heat off. It is a saftey precaution dryers have to prevent fires starting in the home
May 23, 2010 | Dryers
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Natural gas dryer running too hot
I suspect you have a blocked air vent. A blocked vent will make you dryer run hot. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not venting properly
Unplug the dryer.
Raise the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
It is probably turning on the shaft.
If so, replace the blower wheel.
If not, dig the lint out of the vent between the wheel and the rear of the dryer.
Mar 12, 2009 | Maytag Dryers
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
I am looking for a tint trap for a Maytag dryer model #DE303 Series 07 Serial # 189625 XJ
Try partsstore.com as they do have your part in stock. I would phone them to make sure their website information is correct. If for some reason this did not help you you can try the chat portion of this website
Sep 07, 2008 | Maytag Dryers
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
