Question about SanDisk Sansa e200 MP3 Player
New songs will not appear, deleted songs won't go away.
This has happened more than once...
Today I downloaded about 20 new mp3s (I put them in my SanDisk's folders correctly), and got rid of about 20. When I unplugged the device, none of the new songs appeared and all of the old songs were still there and had the 'Bad Track' label.
Help please!
  • 8,596 Answers
Re: New songs will not appear, deleted songs won't go away. - SanDisk Sansa e200 MP3 Player MP3 & Digital Media Players
Renew your music sub and resync
Posted on May 26, 2008
0 characters
3 Points
My mp3 player is saying profile requires 20mb free space shutting down what do i do?
dude hook it up to your computer right click view what windows says is your space IS IT FULL OR CLOSE ?yes, delete some songs/mp3s no its probably junk or you can try to format via windows and the right click thing and put on some new mp3s you may of possibly downloaded a corrupted mp3 to the device
Nov 27, 2010 | RCA OPAL M4001 MP3 Player
I keep putting songs on my ipod and the computer says that it has been downloaded but when i get on my ipod it dosent show up some people are saying it needs to be synchorized but i dont know how to do...
use itunes to put the songs on your ipod it freely downloadable at the apple website at
Once installed it will ask you if you want to put any mp3s on itunes once they are there you can then drag songs onto your ipod once connected by your usb cable. Or use ipod panel to synch songs from there.
Hope this helps
Oct 31, 2009 | Apple iPod nano
Ilo 1GB 3.101.103 MP3 Player = MTP Device?
Uninstall MTP Device in System --> Hardware --> Device Manager
May 18, 2008 | iLO MP3 Player
Wont put songs on
I would wait for the writing message to go away before disconnecting the player - this is the standard message it will give you when you are transferring songs to the player. If it still says writing after 5 minutes (this is assuming you are not trying to load more than 20 songs at once), then you might have a real problem.
Make sure the files you are trying to load do not have DRM encryption on them, and also make sure they are in mp3 or wma format.
If you have Windows Media Player 11:
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
Mar 16, 2008 | SanDisk Sansa E280 MP3 Player
Mobiblu dah 1500i
Reload the firmware. The firmware gets a hiccup after repeating songs/switching through songs quickly. Make sure you take your mp3s off before you reload the firmware for the songs will be deleted.
- [this_guy]
Jan 01, 2008 | Hyun Won MobiBlu DAH-1500i (1 Gb MP3...
Delete songs
You should be able to hook your mp3 player up to your computer with the USB cable. This will allow you to browser the directory where the songs are and delete or add new songs. Your mp3 player will appear in your computer as a removable disk. The songs that you put on your mp3 player need to be in mp3 or wma format. I also found the instruction manual for your product in pdf format.
Dec 11, 2007 | GPX MW3816 MP3 Player
How to transfer music
windows media dont surrport mp3 u cant play mp3s but thats it. when u plug in the usb from ur mp3 player it should pop up new hardware found in the right bottom corner double click on that i should open up the mp3 folder after tat just click and drag the music u want in to that folder and ur on your way.
please rank
Dec 07, 2007 | MP3 & Digital Media Players
How do i keep,my songs on my mp3 player,without overwriting them?????
in order to help you illl need more information, like what programs are you using to download and convert them into your mp3 player? i use rhapsody, because when i used to use windows media player it would give me the same problems you seem to be having. P.s. my e250 screen is broken v.t it was the only thing holding my entire colection of kick ass songs, most of which are irreplaceable due to undownloadableness. i could kill myself
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Can i put new songs onto my ipod without the other ones deleting?
May 26, 2007 | Apple iPod nano
Someone else mentioned this problem....I thought it might be that some files have different artist names (or vice versa?). You really have to keep a clean library with proper summary fileds (artist, title, track number, etc.). First of all, you should always be using MTP mode (USB mode in Sansa player settings). MTC mode is problematic. Are you using WMA or mp3 files? The other person had the same problem using WMA files....maybe using mp3s would fix this.
Dec 03, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
60 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
