Wireless is not working. How can I determine if
Wireless is not working. How can I determine if setup was properly installed?
  • 2 more comments
  • mlayman126 Jul 15, 2009
    The model number is DIR-615. What do you mean by the type of wireless?
    D-Link DIR-615 is the model number of my wireless router. I hope this is what you need.
  • mlayman126 Jul 16, 2009
    The device is D-Link model DIR-615 and is a wireless router. I checcked the hardware manager with the result: Atheros AR5007 802.11b/g wifi adapter. Device working properly. What do I do now?
  • Bruce Weaver
    Bruce Weaver May 11, 2010
    What is the model number and type of wireless. Generally if it is a router/wireless you can type in the generic IP address of that device.D-link is 192.168.0.1. Then go to the wireless settings to verify setup. Bruce
    President:
  • 1,383 Answers
Press windows + pause break key so you get system proeprty window then go to hardware then go to device manager then you can see all drivers check network adapter and check for wi fi drivers .if it is installed properly then your wi fi is ok .then check in router you can access your router with following link
http://192.168.1.1
or
http://192.168.0.1
for belkin router
http://192.168.2.1
type user name as "admin" and password as "admin" or blank or "password"
then check wi fi internet is enabled in router.
Please don't forget to rate my solution.
Let me know if you have any confusion.
Posted on Jul 15, 2009
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
Tip
Installation CD for the print server
If you are having trouble going through the setup process on the installation cd do the following:
  1. Disable any encryption settings on your wireless router.
  2. Disable MAC filtering.
If these features are enabled during the installation setup process, the wireless features will not work unless you go into the admin settings of the print server by typing the IP address into internet explorer. Type in the correct encryption settings.
Linksys has a provision in the setup software to key in the correct encryption however the software doesn't put the information in properly. This will cause the wireless not to work and allow the print server to work only when it is wired to the network.
Encryption settings have to be entered through the administration settings of the router by typing in the IP address of the print server using internet explorer.
on Jul 20, 2008 | Linksys WPSM54G Print Server
It cannot detect the wireless detection
Hello Friend
Below is the link of User manual of Encore wireless router ,
A short reading of topic "Installation setup" of Wireless router Manual will give you a cross check from your configuration setup.
http://www.encore-usa.com/download/manual/ENHWI-G2_Manual.pdf
, Also check your Wireless Receiver card is properly working or not
Sep 06, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Wireless not working
remove wireless security as Linksys won't accept certain WEP keys
ping the device to determine that it is there. This often works and shows it is a Linksys setup problem. If can't even ping the device then you have another bigger problem.
Finally, move the camera to under 5 feet of the wireless access point and then Setup will work. After setup then you can move camera out further.
Apr 11, 2009 | Linksys Wireless-G WVC54GC Network Camera
I have a HP Compaq NC6000 laptop. Cannot get the 2200 BG wireless card to detect a wireless network even though one is available. It says it is installed and working properly. Any suggestions?
These are very flaky wireless adapters make sure you have the hp 2200 bg wireless drivers setup correctly.
They will appear as working correctly in device manager but do have connectivity problems.
Also make sure that wireless zero config service is started.
Another method would be to connect and setup through Intel proset utility
Mar 14, 2009 | Computers & Internet
The cd player doesnt work so i can't install the installation for wireless internet
you can access the router's setup page and setup your internet connection form there. follow the steps below
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  3. then setup your connection according to the settings provided by your ISP
Aug 05, 2008 | NetGear WGR614 Wireless Router
Dell D600
hi friend
did u your laptop has wifi if have then can u install proper driver if u have installed proper then go in control pannel there is last option in wireless network setup if u have wifi modem it will detact your laptop setup your wifi network
thnx using fixya
Jul 08, 2008 | Dell Latitude D600 Notebook
Wireless Setup
well..I suppose we should determine that you have your small office/business network set up first, right? it's under network connections. If it's not there, then your printer will stay invisible. Is this a replacement or new install?
Feb 17, 2008 | Brother MFC-8870dw Wireless Multifunction...
Setup for wireless internet
go start/control panel /wireless assistant configure it there !
make shure to askyour husband if is cryption for router is wep or wap it makes a difference there but first configure it in the control panel!
Jan 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
