I have a 1998 dodge caravan and it starts and runs for a while. After driving it so far it just stalls and won't start again. What could be the problem?
try this it may work as i dont know your area, as im in uk but remove the air temp sensor on the filter box and see if that works, if it does it could just need replacing or you need a remap to the ecu as its reading the wrong signal. could even be a bad connection to the ecu so might just need a good clean on the ecu connector.
Sounds like low voltage check voltage at the alternator with engine running it should be 13.5-14.6 if its anything less than 13 volts replace alternator.
My 98 plymouth grand voyager was having same problem changed several sensors before finding a very dirty crankshaft position sensor. After removing and cleaning my problem has disappeared. Youtube has a video on replacing this sensor. Careful when reinstalling. Position is critical to far in and hits flywheel. too far out and will not start.
Check the sensors on the throttle body. There is a sensor that controls air to fuel ratio. If that sensor is bad then the car will run and then stall out while in drive. I had the same problem when it was cold outside last winter. If you dont want to dish out the money without knowing if it is that part at fault or not then start the van pop the hood and located the throttle body. Place your hand on the sensors and give them a little shake and then make sure they are plugged in all the way. You could also turn the van off and unhook the sensor clean the connectors and plug it back in. That should do the trick and if it doesnt stall anymore then I would replace those sensors if I was you. One more thing. If your giving the sensors a tug while the car is running and you hear it going to stall you could located the gas pedal cable and give it a rev or two by hand so it doesnt stall out and turn off.
By the way. You van isnt over heating at all is it?
