As I watch tv the menu keps popping up. I exit the menu and it pops up again a few seconds later. Tried everything, including unplugging the tv for a couple of hours. That almost worked, but after a while the menu started popping up again.
    Problem Solver:
  • 17 Answers
Order from the menu or go to a different restaurant
Posted on Jul 15, 2009
How do I reset the tv to the original? How do I make the menu quit popping up on the tv screen? The menu pops up on the screen every minute or so and stays on for a couple seconds.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 15, 2015 | Dynex Televison & Video
The TV menu options keep popping up aprox. 15 mins after turning the TV on.
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 09, 2017 | Televison & Video
My tv menu keeps popping up every few seconds.
MENU KEEPS POPPING UP WHILE WATCHING A PROGRAM. I REPLACED BATTERIES ON REMOTE CONTROL AND HAVE UN-PLUGGED THE TV SET. I OWN A 42INCH PHILIP PLASAM TV MODEL#42PF9630A-37
Oct 02, 2009 | RCA R61WH76 61" HDTV
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Televison & Video Logo
252 people viewed this question
Top Televison & Video Experts
Electro Med Services...
