Question about Baby Gear
I'm trying to set up a pack and play for my grand daughter.
How do I get the sides to lock in place?
Pull the middle up about halfway. then pull up on the sides.
Posted on Jul 15, 2009
I cannot assemble my grand daughters play pen , I cannot get the sides to stay up
With most play pens you need to lock all 4 sides into place before pushing the center down.
Jan 25, 2011 | Toys
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
DIRECTIONS FOR GRACO PACK 'N' PLAY
pull and turn the center of it then try to open the side lock. they have to be horisontal from both side of each
Good luck
Sep 09, 2009 | Graco Pack 'n Play
How do you set up a pack and play?
Open it part way but do not push the center of the bottom all the way down. Raise each of the side rails and make sure they lock in place in the full up position, When all four side rails are locked in place, push the bottom center all the way down until it locks. Put the the bottom pad in place and secure it with the velcro tabs through the opening in the sides.
Jul 06, 2009 | Baby Gear
Gramine gps is locked with a pass word.
Thankfully the solution is very simple to your problem. The only way for the Garmin to accept a setting of a password is if you also define a secure geographical spot right after the PIN code setting.
If no safe place is defined, the lock will not engage and the PIN setting attempt is void. So if it is locked it means your daughter has stored a safe location as well (you just click ok so it is easy also for a 3-year old).
At this geographical spot the GPS unit will be unlocked, and you will be able to change the PIN code to your liking or remove the lock.
So all you need to do is to recollect the specific geographical place your daughter may have played with your GPS, bring it to that place and switch it on: no PIN code is asked for when you found the correct spot. You may need to wait a few minutes for the unit to locate satellites, then it should unlock.
Jun 03, 2009 | Buck BENNETT DVD GARMIN NUVI 750 760/770
Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
May 26, 2009 | Graco Pack 'n Play
Can't get evenflo babygo pack and play support bars to lock
Pull center floor up, then lock all top rails, then push down on center floor.
Jan 16, 2009 | Baby Gear
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Graco pack and play sport
I saw the solution on the Graco site. I was putting the bottom of the Pack and Play down first, I found out you need the do the sides firstl
Apr 27, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Pakc & play set up
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Jan 13, 2008 | Graco Quattro Tour Kentshire Stroller
Baby Gear Logo
54 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
