Question about TV Accessories
My pioneer stereo amplifier sa-1480 will not come on
The remote works on the external pieces but my hand or remote the amp will not ture , the stand by lite is lit, is their a reset switch. i no its old but so am i
0 characters
1 Points
How to connect external speakers to technica tv
If they're just basic speakers from a stereo system, then you can't connect them directly. The TV doesn't have the sockets nor the power to drive them. You need an amplifier.
For stereo PC speakers, if the TV has a headphone jack socket then you can use that. If it doesn't have that socket, then you'll need to use the TV's optical connection on the back of the TV with an optical to analogue converter box. Amazon does the Cable Mountain box for under 10 quid. This will convert the light signal in to an electrical stereo signal that the PC speakers will understand.
One issue going for PC speakers is that they rarely come with remote control. The volume can't be controlled via the TV's optical out. So you'll have to get up and change volume from the speaker's control instead.
Sep 05, 2014 | Audio Technica TV Accessories
Why can't get the TV audio to play through my stereo
audio out fibre optical to amplifier to analog converter or
HDMI TO analog RCA white and red .to reciver .
Aug 25, 2014 | Sigtronics Stereo Audio Input Cord
How to program this remote.
Hey mate is there a set button on your remote? or similar type of command, if so, turn the tv on by its main on/off button on the tv itself then stand back and point the remote at the tv, now press the SET button down for a few seconds, if you see a flashing light on your remote this means it is searching for a IR signal, cool now just keep pressing the on/off button on the remote say every 2 seconds, as soon as your TV turns OFF press the SET button on your remote and hopefully it should be tuned in and you can use the remote to turn your TV back on and play with menu and stuff. If this worked dude you can join my... getting a remote to work easy club .
May 23, 2013 | TV Accessories
Where is the power button of this aquos cardio vision tv? Is there any other way to turn on tv?The power button on remote can't work today.
First thing if there's a TV Button they pushing cause someone might of pushed the SAT or. DVD button. If that don't work check your battery's. some times I tap mine for hand hand lightly and then it works Good luck
Mar 19, 2013 | TV Accessories
I just purchased a ge amplifier antenna for my magnavox tv and i am only receiving 1 channel and its very fuzzy
Your television has generally several receiving modes...such as video 1/2, cable, dvd , satellite, ext antennae. So make sure that it is set on external antennae. Then you will probably need to program in the stations that it is receiving again.. Meaning that ..before bought and installed this product your tv only recognized the channels with you need to run a new channel scan.. One last thing make sure vcr/dvd/tv button on any other devices you have is in the TV position..or if it is not make sure the signal amp is going into the input plug in the back of that device...rather than directly into the back of your tv... I think the combination of these things will solve your problem. good luck
Jun 22, 2012 | GE Amplified HDTV Antenna 24700
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
Gemini card reader is not working
* Contol Panel
* Performance and Maintenance
* Administrative Tools
* Services
* Smart Card( check if its active and started manually)
* If not click twice and start it ,then click ok.
* Reboot your computer (I shut it down holding the main button in for a few sec)
If thats ok, remove the cables from the motherboard. Boot the pc, shutdown, reconnect the cables & reboot.
Jul 02, 2009 | Pioneer Mag Card Reader (Tracks 1 and 2,...
There should be a diagram entitled "adding and amplifier to a factory stereo" in the owner/install manual of the high to low convertor. You need to signal tap some audio signal from your front or rear stock speakers in the car and those wires need hook up to the high to low convertor's input side. From the convertor you connect RCAs that go to your amp. In other words find your rear speaker wires and hook them to your adapter then hook up the rca wires
Dec 02, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
TV Accessories Logo
344 people viewed this question
Top TV Accessories Experts
Brian Sullivan
Brian Sullivan
Are you a TV Accessory Expert? Answer questions, earn points and help others
