Question about Dewalt 3800 PSI Pressure Washer
RUNS FOR 20 MINUTES AT FIRST THEN SHUTS DOWN, THEN WILL ONLY RUN FOR 5 MINUTES AT A TIME AFTER A SHORT WAIT.
  • 174 Answers
Have you checked the oil level?
Posted on Jul 17, 2009
I have a 6200 Woods zero turn mower with a 20 hp Kohler Command. Runs anywhere from 5 to 20 minutes then shuts down. Put an electric fuel pump on it, no change. Good compression. Good spark.
Dear Doug,
There are three reasons you could get "run-on".
Probably you have one or both as your problem concerning the 5 - 20 minutes automatic shut off.
1) The timing is off, causing the engine to have a tiny bit of gasoline left over, which is just enough to give power to keep running.
2) The engine is getting too hot, which again causes it to keep on running after the key is shut off.
3) If the engine has a carburetor, the needle & seat could be dirty or sticking,or the float sticking, causing it too have too much gas, and that will keep it running.
God bless your efforts to fix this.
Oct 24, 2017 | Cars & Trucks
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Have a ploaris 400 2005 turns on runs great for bout 20 minutes then shuts down. wait bout 15 minutes will start and run again for a short time. What is the problem
most likely a fuel issue. has it been sitting up ? if so if its got a carb it prob gummed up, pour some seafoam into the gas tank with fresh gas and run it, try and keep it running with the throttle, it might clear some varnish out the carb if it not too bad, if tht dont work and it is a carb engine then the carb will have to be removed and cleaned. if it a FI engine then you got a bad full pump more than likely
Oct 01, 2014 | Polaris 2005 Sportsman 400
Why would my harley davidson 1998 dyna wide glide stop running after a short trip after being shut off for 20 minutes and restarted?
when it shuts down does it sputter first or is the shut down immediate without warning. sputtering is usually a condition of lack of fuel.any intake leak at the manifold especially at the head will cause "sneezing" out of the carb. Restart can be difficult and intermittent. A weak ignition module especially the adjustable kind can be unpredictable. a lot of the after markets are adjustable.A 1998 scooter tells me you have an Evo and being it's 16yrs old the likelihood of having a stock module is nil. check the plug where the module plugs to the ignition harness as well. Often times,because of it's age,these pins turn green or they either bend or they pull out just enough to break contact. I've also experience cracking of the wire insulation causing temporary short. shutting down the engine and difficult restarts.As with all jobs,check the simplest and obvious and don't start buying parts until you have checked all connections especially at the module where it meets the ignition harness.
Jul 19, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Oil light comes on and engine shuts down at the same time. Oil level is good. This happens after about 3-5 minutes on the road. Engine will start up again if I wait a few minutes. The engine stall happens...
try a new oil pressure sender,
you could also fit a gauge into the oil sender hole and see if it has oil pressure.
There could be other reasons like a faulty oil filter, problem with bypass in oil pump, or a shorted or broken wire causing the shut down and light on.
If it is actually losing oil pressure and shutting down it would probably be making strange noises
Jun 10, 2011 | Honda VT 750 Shadow Aero Motorcycles
This question is for the 24v model which I don't see on here. The problem being my trimmer will just stop like it's out of charge. Then I wait a while and it will go again for a few minutes. The longer I...
Assorted users have had issues with the chargers and batteries on these units. Check that any air vents that go to the electric powerhead are clean and clear. It could be getting overheated and shutting down.
Oct 21, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Suzuki liana 2003 only done 14000 km will only run for 20 minutes
Have you checked all fuses for the cooling fans? Seems to be that the car is warming up to temp and then some, and protecting itself from overheating by shutting down the engine.
Jan 04, 2009 | 2003 Suzuki Aerio
Brand new right out of box Everstar MPK-10CR-1 portable 10,000 BTU's
It sounds to me like it is overheating. Make sure that all of the literature that came with the unit is accounted for. Many times the manual or instructions are blocking the exhaust causing it to overheat. If this is not the problem then I would suggest exchanging it for a new one. It may be a manufacturer defect.
Jun 27, 2008 | Danby DPAC8020 Air Conditioner
Dewalt 3800 PSI Pressure Washer Logo
447 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
