Question about Xerox CopyCentre C20 Black and White Copier
My xerox c20 is printing a descriptive report of what is about to be printed. How do I shut this off.
    Scholar:
  • 92 Answers
Go to the driver opts and disable the bannersheet
Posted on Aug 27, 2010
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
After all checks and maintenance on a xerox copycentre c20 the copy is still blink.
Will it still run the billing meter report? Is there print on the paper when you print the report?
If so, the issue is with the scanner. If not then the issue is the laser.
Feb 07, 2011 | Xerox Office Equipment & Supplies
Which toner I could use for copycenter c20?
Use OEM. Xerox cartridges only if you want reliable clear prints.
I have tried many different generics. I wouldnt recommend using anything but the OEM cartridge. They just perform better.
Oct 23, 2010 | Xerox CopyCentre C20 Black and White...
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
Xerox c20 doesn't print. the paper runs through & comes out blan
hello sir; you said this one is brand new, did you follow the installation instruction, no matter what, just di it again,
1, press "menu" ,
2, press up/down arrow keys until"new drum" display
3, press "mode/enter"
4, when you see"new drum unit?" press "1" to select "yes"
5, turn power off and on .
Dec 28, 2008 | Xerox CopyCentre C20 Black and White...
Not printing full A3
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
Jan 31, 2008 | Xerox DocuPrint C20 InkJet Printer
Xerox CopyCentre C20 Black and White Copier Logo
53 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
