Question about Acer Aspire 5920 AS5920 Notebook
Battery seems to not charge anymore
I have an acer aspire 5920 and suddenly my battery doesn`t seem to work anymore. When i plug the charger in the battery just doesn`t charge. Before the computer worked fine,its just the battery. do i have to buy a new one now? i bought the computer in germany but there`s still a warranty. what can i do?
  • 24 Answers
You can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Posted on Jul 15, 2009
SOURCE:
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
BATTERY DOESN'T CHARGE ON MY ACER ASPIRE ONE MOD#KAV60
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
May 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 5920 will not power on. Power Cord, Charger, Adapter and Battery work fine. Adapter lights up green, no power light on computer keyboard or On/Off switch. CPU Fan is not working. Is there a...
There is a cmos/ rtc battery but that would have nothing to do with powering on your laptop. Most likely there is an issue in the circuit at the DC power jack. If the connection seems loose, or moving the plug at the point where it connects to the computer gives a glimmer of power then it is the jack. The DC jack is usually soldered to the motherboard and requires some knowledge to repair. If the jack is okay then there is a problem further up in the power circuit on the motherboard which means trouble.
This is what you power jack looks like and yours is not soldered, but has a 4 pin connector that plugs in to the motherboard. Much easier to replace than a soldered connection. Click HERE to see it.
P.S. Just because there is a green light on the adapter it doesn't mean power is being distributed to the connector tip. You may want to try a different adapter before spending money to have it diagnosed.
Apr 18, 2011 | Acer Aspire 5920-6727 Notebook
Not charging
If you have tried both adapter to swap as well as the battery the problem might be with you MOBO or mother board try to flush the bios first or get the latest bios update of you system .
ERNZ
Feb 03, 2010 | Acer Aspire 5920-6335 Laptop
Acer charger plug no longer charges
It sounds like the connector on the motherboard has come loose. Don't continue messing with it as you will make it worse. You might be able to have a technician resolder the motherboard connector. It is a common problem with a variety of laptops and a lot of times can be fixed for a modest fee.
Sep 15, 2009 | Acer Aspire 5920-6727 Notebook
Acer 5920 wont charge.
The problem is not the ram.
Remove the battery and try to boot the laptop up on AC power only, if it boots up then the problem is not the charger.
If the result is the same then there is a problem with the laptop's motherboard or the adapter itself is faulty.
If the latter is the case then you will need to take the laptop to a service center or PC repair store.
Regards.
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 3050 new battey will not charge
Sometimes batteries need a full 24 hr initial charge before they will work. You would be advised not to use the M/C during this period. Also it will take several charges before the battery reaches it's optimal performance.
This could be the problem so it's worth a try.
Aug 21, 2009 | Acer Computers & Internet
Acer Aspire 5920 AS5920 Notebook Logo
276 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
