Question about Ariens Garden
On Ariens Model 927044 I cannot get the deck and the belt adjustment set right. If set the deck cannot get the belt tightener to shut off and if get the belt shut off cannot move the deck height lever back?
  • 37 Answers
SOURCE: Ariens sierra 1440G belt configuration
Hi, you may have more than one problem. There should be one belt from the mower deck going to the electric clutch pulley which is on the engine shaft. On the shaft there are two pulleys, one belt comes from the mower deck, and the other comes from the transaxle pulley. check to see if your belts are in the right areas.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 27, 2008
  • 6 Answers
SOURCE: The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
Posted on May 26, 2009
  • 218 Answers
SOURCE: can someone please help lookingh for belt routing
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Posted on Jul 08, 2009
SOURCE: My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Posted on Sep 29, 2009
stmc97
  • 41 Answers
SOURCE: the deck drivebelt slipped off the blade pulley
There should be a diagram on the mower deck itself usually on top of the deck on either side of the mower, and sometimes on the front. Look for this decal and it should give you the proper diagram.
Let me know if you find it, if not, I will try to locate a diagram for you.
Chip
Posted on Apr 11, 2010
Have an Ariens Max Zoom 60, when engage the mowing deck the engine loads up and RPM's drops way down" Have tightened and loosened belt, what else can I Try?
Something in the mower blade drive is binding up. That puts a drag on the engine and causes the slow down in RPM.
Jun 16, 2017 | Ariens Garden
What size belt other than the deck belt do I need for an ariens riding mower 42" cut?
I usually visit the manufacturer's website and download manuals that provide specific information. You will need the model number and serial number of your machine.
http://ariens.custhelp.com/app/answers/detail/a_id/15/
Apr 06, 2016 | Ariens Garden
YT4000 blades not turning
I am wondering if you have the right belt for that machine. or possible its not installed properly.The belt should be tight when engaged. The tightener may not be working as well. These are things to check. Does the belt try to tighten up when you engage it?
I am wondering if the wrong belt was the reason why some one lowered the deck too low.
Apr 28, 2015 | Craftsman YT 4000 42" Briggs Stratton 24...
Replace deck on Precor 9.45i
Replacing a Treadmill Running Belt and Deck Following is a basic guideline of removing and replacing the running belt and deck on a treadmill. Due to different brands and designs of treadmills, the following should only be used as a guideline. If any of the information is not exact to the treadmill being serviced, refer to the service manual or call Sportsmith for further help. Tools Needed: Phillips Screwdriver, Set of Allen Wrenches, Set of Box End or Open Face Wrenches (Tools needed may vary depending on treadmill. )
  1. Switch the Power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Remove the finger guard retaining screws and carefully remove the finger guards from the deck at each end of the rear roller.
  4. Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
  5. Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
  6. Raise the shroud and secure it with a bungee cord.
  7. Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
  8. Now remove the front roller retaining bolts.
  9. Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
  10. Loosen and remove the deck mounting hardware.
  11. Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
  12. Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
  13. When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the newly installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit.
  14. Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
  15. Be sure the deck is lined up with the frame and push the deck to the left side.
  16. Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
  17. Re-install deck mounting hardware. (Check with mfr. for proper torque during install process.)
  18. Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
  19. Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
  20. Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
  21. Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
  22. Tighten each rear roller bolt the number of turns you kept earlier for reference.
  23. Now, Plug in and power on the unit.
  24. Carefully remove the bungee cord from the shroud and lower it back into place.
  25. Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
  26. If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
  27. Caution: make very small adjustments such as 1/4 turns and then watch the belt for several moments before making another adjustment.
  28. Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
  29. Now use the unit at a jogging speed to check for belt travel or slippage.
  30. If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
  31. Install the finger guards once you have enough clearance from the rear roller.
  32. Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
How to Replace Treadmill Running Belt and Deck
Feb 22, 2014 | Precor Exercise & Fitness
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
How to replace a Treadmill Precor 9.31 belt
  33. This concludes our instructions of how to install a replacement treadmill belt and deck.
Oct 16, 2013 | Precor 9.31 Treadmill
Replacing precor 956i treadmill deck
Oct 09, 2013 | Precor 956i Experience Series Treadmill...
Cant find the PTO deck belt for a Ariens Sport Zoom Model 915031-1232. Ita a zero turn mower. The manual calls for belt # 07242700 cant find it anywhere! Help.....
I own this model as well. The manufacturer issued a "cutting improvement kit" for this model number. The belt number has changed as well. The number you now need is # 07242200
I am in the process of ordering one for mine right now. Good luck!
Apr 14, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do you tighten PTO belt?
If the belt is loose it probably needs replaced or has jumped out of one of the pulley or belt guards allowing it to be sloppy. Belts get stretched in many different ways, tall grass, grass getting in the pulley, or they just plain stretch. First though, check to be sure the belt hasn't jumped out of it's normal runway.
Jun 23, 2009 | Ariens 34 In. Zoom Series Riding Mower
Nov 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
61 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
