Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Have poulan pro gas blower,it is geting fire but will not start
    President:
  • 1,129 Answers
Spray carb cleaner in the carb with throttle at full then hold the throttle wide open for three pulls, if it doeasn't start remove air cleaner and put a finger over the carb hole and have an assistant or yourself pull the cord this may clear out the debree blocking the flow of gas otherwise the carb must be removed cleaned and the vacuum diaphram replaced.
Posted on Jul 15, 2009
Poulan pro bvm Poulan Pro bvm200vs blower won't start
If the blower has been setting or stored for a while then you need to check the fuel lines and be sure they have not rotted out because ethanol gas will eat them up. If the lines and the fuel filter in the tank is ok then you may need to rebuild the carb. it is not difficult to do. Just takes a little time. You can watch a video on youtube.com to see how to do it. Before doing the carb. check and make sure there is no cracks in the primer bulb if one is on the blower and check to be sure the plug is firing and the air cleaner is not plugged. Hope this helps.
Sep 30, 2016 | Poulan Garden
How come no spark?
I would change the plug first and check to see if the coil is firing by grounding out the plug and see if there is fire. If not the ignition coil or unit maybe bad. Hope this helps.
May 18, 2014 | Poulan Pro 25cc 2-Cycle Gas Blower...
New blower will not fire
Check for spark at the plug by using a simple spark checker tool. Got to have both or it won't start.
Feb 26, 2014 | Poulan Pro Gas Blower Vac BVM200VS
Poulan pro sm400 will not start new plug new gas clean filter no fire to plug what next
I HAVE DE SAME PROBLEM, TODAY I´M GOING TO CHECK DE CIRCLE BAHIND THE FAN PROBALY ITS MOVED (ROTOR)
Mar 28, 2011 | Poulan 25CC Gas BlowerVac
Poulan Pro won't start
1. You may have old gas in the tank.
2. Fuel mixture may not be quite right. Pour out and put new in it. Otherwise you may need to clean the carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Nov 29, 2009 | Poulan Featherlite Gas Blower, with Low...
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Sep 22, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
327 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
