Question about Motorola Mobility RAZR V3i Cellular Phone
Inserted a new memory card and got the message, "card not formatted, format now?" I say yes and it says can not format. What gives?? Any suggestions to fix this?
    President:
  • 1,462 Answers
This is due to the problem with the memory card, your memory card may be damaged....Try replacing the card
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Jul 15, 2009
Memory card will not format
If other memory cards take the format then your card is fubar.
Aug 25, 2017 | Kodak EasyShare M863 Digital Camera
On pokemon XD it keeps saying that the save file currupts I have alot of room on it but it still crrupts so what do I do to fix this
  • Fully Corrupt:
    When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
    Follow the steps for formatting a memory card.
    For specific issues with the Memory Card 1019, please click here.
  • Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
  • Data Area Only Corrupt:
    When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
    Follow the steps for deleting a file.
  • Memory Card is Damaged:
    If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
    Please use our convenient repair options.
This procedure is only used if a corrupted Memory Card is inserted into the Nintendo GameCube.
If required, this procedure will begin automatically when you select "Memory Card Screen" from the main menu. You cannot use this procedure to erase files from a useable Memory Card.
  1. After selecting "Memory Card Screen" from the Main Menu, if your Memory Card requires formatting, a window will appear to ask for confirmation for formatting.
  2. Use the Control Stick to select "YES" and press the A Button
  3. A window will appear to notify you that all data will be erased and ask again for confirmation for formatting.
  4. Use the Control Stick to select "YES" and press the A Button.
NOTE: When you format a Memory Card, all data will be permanently erased and unable to be recovered.
Jan 11, 2011 | Nintendo GameCube Console
Memory card issue
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the new card and do the format thing again.
Jun 20, 2010 | FUJIFILM FinePix JX250 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
I have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card requiers formatting,ipresse continue to start the formatting but it keeps giving the same message how do iformat...
The lever on your card might be turned the wrong way. Pls. readjust and try again.
The card might not be supported:
You camera Memory card support : SD/MMC up to 1 Gigabyte
Good luck pls. rate me and/or recommend me if helpful
TXS
Nov 28, 2009 | Kodak EasyShare C315 Digital Camera
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Out of Memory message
try to formatted the internal memory and see
Oct 13, 2009 | Nikon Coolpix 5700 Digital Camera
Memory card
yes Formatting will erase everything on the card. The 2 cameras probably use different formats or even different qualities. You should upload pictures before switching the card between cameras. Hope this helps
Sep 12, 2007 | Fuji FinePix A345 Digital Camera
Motorola Mobility RAZR V3i Cellular Phone Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
