Question about Hitachi C10FCE2 10" Compound Miter Saw
Saw runs continuously
We have a Hitachi Compound Miter Saw Model C10FCE. Once plugged in, the saw immediately runs until it is unplugged from the power source. Releasing the on/off switch does not shut off the saw. It even runs in the up position. We have checked the micro switch, on the handle, contintuity is good. Any ideas would be helpful. This is a nice saw but very seldom used and now is dangerous!
    President:
  • 1,714 Answers
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Posted on Jul 15, 2009
Skil Compound Miter Saw laser quit working, Help
SKIL 10" Compound Miter Saw 3317-01
www.skiltools.com/Tools/Pages/ProductDetail.aspx?model=3317-01 Skil10 In. Compound Miter Saw with Quick Mount System and Laser Cutline. Model #3317-01 ... manual Get Manual (PDF); parts list Get Parts List (PDF) ...
[PDF]Operator's Manual 10 in. COMPOUND MITER SAW WITH ...
c.shld.net/assets/own/00921236e.pdf
Dec 14, 2015 | Skil Saws
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
Hitachi c12rsh brake
There are a few things that can cause this:
1) Check the brushes - make sure they are not severely worn and make sure they travel freely down the brush tube & contact the armature well.
2) If the brushes are OK the problem is most likely the switch. Tools with a brake have a 2 pole switch - one set will be normally open and one set will be normally closed (Most switches have a diagram printed on them) Disconnect the leads (keeping track of where you removed them) and using a continuity tester check the switch - you should get a reading between the normally closed contacts and lose it when you pull the trigger. Most likely you will find you are not getting a reading on the normally closed side and that would be your culprit. Hitachi C12RSH 12 Sliding Dual Compound Miter Saw Parts
Mar 16, 2015 | Hitachi C12RSH 12" Sliding Compound Miter...
How do i replace switch on Hitachi miter saw
Oh come on.
You know the answer.
You start taking out screws until you can see the switch and then you replace it with a new one from the parts supply store.
Then you put all the screws back in.
Oct 16, 2014 | Hitachi C10FCE2 10" Compound Miter Saw
Braking on miter saw not working
Try fitting a new set of brushes first otherwise it could be that it needs a new field coil.
Dec 27, 2013 | Hitachi C10FSH 10" Dual Bevel Slide...
Craftsman Miter Saw stopped working
Are you plugged into a GFI receptacle? If so maybe you have to reset the GFI. I would also check for loose wires on the switch or plug and make sure your cord is good.
Aug 20, 2012 | Craftsman Saws
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
Craftsman 10 in miter saw just stopped working...not getting any power. Any ideas?
Check the brush under the black caps on the side of the motor. Make sure the plug is unplugged while you are checking it out.
Feb 04, 2011 | Dewalt DW715 Heavy Duty 12" Single -...
Hitachi C10FCE2 10" Compound Miter Saw Logo
312 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
