Sunbeam mixer model 1940
The speed control does not always shut off and a few times the speed went from slow to high speed on its own.
  • 86 Answers
Remote problem change remote
Posted on Mar 17, 2008
Speeds do not work in graduations in Sunbeam Model 2371 12 speed mixer
Problem with speed control device. Check switch for continuity with various speed settings.
Dec 24, 2016 | Sunbeam Food Mixers
Sunbeam mixmaster 12
There's a governor assembly inside that is bot working any more.
Sep 15, 2016 | Sunbeam 1957 Mixmaster Model 12 Kitchen...
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
How to disassemble a sunbeam 2370 mixer
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Nov 28, 2013 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Mixmaster will only operatte on high speed.
Are you proficient in electronic component repair? If not, then leave this sort of repair to a service professional.
You can find parts here:
Sunbeam Mixer Parts
Jan 28, 2018 | KitchenAid K45SS Classic Stand Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Mixer motor shut down
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
Nov 15, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Heating & Cooling Logo
194 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
