Question about Whirlwind FH-778 Air Conditioner
No air flow from duct on forced air unit
This is a combined unit of heat and central air( powered by natural Gas)
    Scholar:
  • 91 Answers
If there is no air coming through all of ducts, there are several things to consider. If you turn your thermostat to fan on, does air come out? If so you may have a switching|thermostat problem. May need to change out, not really hard you just have to turn off electric mark wires as you remove and turn back on. If nothing changed, make sure the circuit breaker has tripped, sometimes its hard to tell so flip it all the way off then back on. Now try to turn on again. If it comes on you need to find out why it's tripping the breaker, merely resetting it can pose a danger for the future. Professionally servicing the unit is important to the longevity of the unit. Now if you find out that unit is coming on but no air is coming out, it could well be that a duct has blown free and is spilling into attic or crawl space. Sometimes the unit forms an ice block in the evaporative area of the unit. In this case it would need quite some time off to thaw. Also the fan motor may be burned out. In that case you would hear part of the unit working with no output. These are a few of the most common problems with this condition.Most of which needs to be addressed by a Tech
Posted on Jul 15, 2009
I want to connect my heating system with my generator. It's a forced hot air system natural gas by York.
yes, you need to have at least 120volts and make sure your generater can power at least 3000 watts min not peak.
if you have an extension cord and must find the supply to the furnace
then splice the cord to the supply
then plug it in and there you go.
Nov 02, 2012 | Heating & Cooling
Not enough, hardly any air flow coming thru forced hot air/central air system. Forced air has hard steel round 4" tubing to all rooms. Just recently bought a small ranch with 1000 sq ft that has a...
You have a mess, You need a complete new duct system and new equipment.......
You have a 2 1/2 ton AC which needs 1000 cfm of air to do the job. You need a supply trunk line 8 by 24 inch with takeoffs of a Min of 6" round pipe to each register which will delvery 100 cfm per run 4" will only delivery about 30 cfm per run.... and then you also need a 10 by 24 return Duct to the furnace ....
So that is why the heat exchanger burned up and the that is why the Compressor is noisy because you was flooding back liquid to the compressor... All because of air flow....
If you replace the AC or Furnace without replacing the Ductwork you will burn them up also....
Sorry for being so Frank......
Jun 09, 2011 | Heating & Cooling
I have a Rudd natural gas heater and central air system. The Air has been working fine all summer and now nothing works ,AC,heat and even the fan does not work. I tried changing the thermostat with no...
check for power at unit, as it may be the disconnect fuse/breaker. The only other thing is the main board, but it sounds like there is no power to the unit. I hope this helps Tim
Sep 23, 2010 | Ruud Heating & Cooling
I have an HRV system and want to know if it is possible to run a heat pump through my HRV ducts in the ceiling?
Hi, can you tell me what kind of heat recovery ventilation system you have? Is it a Honeywell, Lennox, ect.? Also tell me about how you have it set up as far as the duct work you are talking about and what kind of heat pump system you plan to install. If you tie your central air heat-pump ducts into the HRV ducts, it will interfer with the air flow. If you will, please tell me what you plan on doing as far as installing what to your home? New duct work for a new central air heat-pump unit, or what, so I will have some idea on what you are doing. Thanks so much. Contact me through my user name below.
Sincerely,
Shastalaker7
Apr 13, 2010 | Heating & Cooling
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
My heat pump is shot and is operating off the emergency heat. Can I just continue to use it this way or do I have to replace the heat pump?
You mean you are using the Emergency heat setting instead of the heat pump????...You're using Natural gas only now tn emergency heat????That's fine...I wouldn't replace a heat pump if you have Natural gas....it's too expensive compared to Gas....you may be able to still use the heat pump as an Air Conditioner only , it depends on what's wrong with it...otherwise you will have to get a Central Air unit instead...cheaper and just use the Gas for heat
Oct 29, 2009 | Amana PTH123B25AJ Heat Pump Air...
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Heat coils in central air conditioning unit look fine under examination, checked with an ohmmeter both coils showed continuity. Power at both coils indicated 110 volts. Unit fan runs fine but there is no...
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
Jan 17, 2009 | Heating & Cooling
My hvac duct work on one of my central air units has a lot of condensation and causing puddles of water throughout my basement. Do you know what the problem is? The drain lines don't seem to have any...
could be just not insulated enough is this a new instalation? the humidity is too high around the ducts is their a return air vant close by that you can open? you need to lower the humidity or seal the ducts so it cant get to them dan
Jul 23, 2008 | Heating & Cooling
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
Heating & Cooling Logo
463 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
