Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
Our Maytag dishwasher will not cycle completely
Our Maytag dishwasher will not run properly. The dishwasher will start to fill up with water then start the wash cycle then will shut down, then start back up again then shut down. It will then just stop. I performed the Field Service test by pushing the Heated Dry button 6 times in a row the the start button. The dishwasher starts the test and then 2 minutes into the test the unti stops and I get the following three blinking LEDs. Normal Wash, Delay and Hi Temp Wash. Can anyone help identify this problem?
SOURCE: We have a Maytag MDBH950AWS Dishwasher that won't start.
I have Miele incognito that when I shut the door it does not turn on? Not sure why it stopped working all the sudden
Posted on Dec 23, 2008
SOURCE: The heated dry and clean lights flash together
I had this same problem. I read on another blog that the manual recommends that you turn the power off to dishwasher. When you turn the washer back on, the lights still flash but then push the off button. The lights stopped flashing.
Posted on Feb 21, 2009
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
  • 2605 Answers
SOURCE: Maytag, MDB9100AWW, Serial # 13125545WZ.
Hello, welcome to FixYa.
I'll start by saying the "2" in the display when you press cancel is normal. If you allow it to complete it should initiate the drain before you press cancel the second time.
Initially It sound's like a fill valve or stuck float assembly, though there are many possible scenarios that can include a heating element or a control board, so I'll need to clarify the unit will indeed complete the cancel if you do not push it the second time and if it does complete the cancel will it then in turn start a new cycle ?
Let me know what you find or if you can add any further details and I'll try to help moving forward any way I can. Good luck.
Thanks for visiting FixYa.
Macmarkus :)
Posted on Jun 16, 2011
  • 1010 Answers
SOURCE: I have a Maytag dishwasher modle MDB7749WM1 and the panal is froze up. How can I reset it? I tried unpluging it and that didnot work.
Replace the panel
Posted on Mar 14, 2013
Dishes not coming out clean
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Film on the dishes
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Jan 01, 2011 | Maytag Dishwashers
Dishes have a whitish-gray film on them
Nov 26, 2010 | Maytag MDB7100AWB Dishwasher
Maytag series 100 dishwasher not completely emptying after cycle
I am having trouble with water not emptying out of dishwasher completely help
Jan 07, 2010 | Maytag Dishwashers
Dishwasher filled with water even though cycle was finished.
the same problem accures with some types of washing machines,when you turn on the machine the control switch sends a signal to a valve on the mains water supply inside the back of your machine telling it to open the problem accours if you live in an area that has hard water because lime scale builds up in this valve so when you switch it off the valve is in the open position because of a lime scale build up, i would say it needs an new valve.adrian
Dec 16, 2008 | Maytag MDB9600A Jetclean II Built-in...
Water does not drain completely, mostly but not completely and just stays there Maytag Quiet Series 100
If the machine has a auto sensor or auto clean cycle it is supposed to keep water in the bottom. The sensor has to stay wet for it to work properly. My Maytag drains, then fills slightly to do this.
Jul 03, 2008 | Maytag Dishwashers
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
161 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
