Heating & Cooling Logo
B
Bob Guy Posted on Jan 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I put a thermostat on this heater - Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
L Pfaff
Level 3:
Top Expert:
  • Reddy Master 11,573 Answers
  • Posted on Jan 27, 2016
L Pfaff
Reddy Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585306
Points
181713
Press the helpful button
Yes Thermostat ( Use Replacement 104458-01R ) R115
2answers
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
My water heater wont heat up
You posted under Marathon electric heater.
If you have tankless or tank-type gas heater, information below does not apply.
Absence of hot water say upper element is not working.
1) This can be caused by tripped reset button located on upper thermostat. Open upper cover and push in reset button. Put ear against tank to hear bubbly fizzing sound. Put insulation and cover back over thermostat. Continue reading information below because reset button trips when thermostats are bad or element is shorted.
2) Upper thermostat is bad. Replace upper thermostat. I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Electricity going to water heater from breaker box is interrupted.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Upper element is bad. Test element. Replace element if needed.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Themostat is bad
If water heater thermostat is bad, buy a generic thermostat at hardware store and install it according to instructions shown on link below:
I usually replace both upper and lower thermostats for about $28.
Lowes sells thermostats and elements.
If your water heater is a single-element/ single-thermostat, you can buy any thermostat with red reset button.
Technically a single-element thermostat has 1 less screw, but either thermostat will work.
If your water heater is 120V or 240V, the same thermostat will work of either voltage.
This is true because the thermostat is a simple bi-metal heat-reading device that does not operate on electric current.
That being said, you might want to test parts before replacing anything, in case problem is element.
To do comprehensive electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Image below shows generic thermostat with reset button. Each of these will work for single-element or dual-element tanks with either 120V or 240V. Wires connect just as they did on old thermostat. Tighten wires very tight. Press in reset button to make sure ECO is set. Put insulation and cover back over thermostat when finished.
3helpful
WHERE IS THE RESET BUTTON ON THE 6EM30-2 FROM AUG 2004?
Electric water heater has panels located on front of water heater.
Remove top cover, and insulation to reveal thermostat and element.
Stand on dry surface, including boards or plywood.
Do not hold screwdriver in mouth.
Do not touch any metal.
Red reset button is located on thermostat.
Push in reset.
If reset will not re-engage, then thermostat may be bad, or some other problem exists.
Screw terminals on thermostat are live.
When finished, insulation and cover must be put back over thermostat so thermostat not exposed to cool air that will cause thermostat to misread tank temperature.
Put ear against tank to hear bubbly-fizzing sound that says water heater is working.
If water heater is leaking or wet, do not touch unless circuit breaker is turned off.
Electric water heater is fully repairable by homeowner.
ECO red reset button trips when upper thermostat senses overheating.
You many have underlying problem if reset continues tripping:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Replace thermostat and heater element get to hot have to reset
Your question is a bit hard to understand.
You need to replace elements and thermostats because water heater is tripping reset button.
Make sure you put factory insulation back in place after working on water heater, or the heater can overheat and trip reset button.
Here's how to replace electric water heater thermostats:
Here's how to replace water heater elements (except for Rheem bolt-in elements)
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If heater still has problems, add a comment
We put in a new baseboard heater thermostat a couple of years ago in our 20 yr. old apartment. When we turned it on yesterday, it shorted and we no longer have any heat coming from the baseboard. Do we...
I have base board heaters in each room and each with a thermostat and hooked to a controller. The controllers activate the heat in the base board heaters. I believe this is how it works. When you activate the thermostat, it sends a message to the controller that sends a message to the base board for heat.
The controllers are Singers. Prbkem 2:. When I turn down the thermostat (to off), I still get heat in the base board heaters. WHY.
I was going to get rid off the controllers and thermostats and buy new base board heaters at Home Depot. The thermostats are on the base board heaters. Will this work.
2helpful
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
2answers
Heater dosne't put out warm air
either have a bad heater control valve, thermostat is not opening, or heater core is stopped up
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
vince
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
