E-Machines T3065 PC Desktop
Problem for E-Machines T3065 PC Desktop
The network connection is causing short
By joelbryant on Jul 15, 2009
The network (RJ45) connection on the t3065 is causing my network switch to start blinking all lights and locks out any traffic. I have installed a seperate nic and used a different cat 5 patch cable and plugged into a different port on the switch with no different results. The switch starts flashing all lights as soon as I plug the T3065 into it, and stops as soon as I take the connection back out.
Comments:
Jul 16, 2009
- I will certainly try this when I get back home. I'll post my findings.
Solution #1
posted on Jul 16, 2009
Not Rated)
ted1430
Rank: Guru
Rating: 89%, 84 votes
It's normal for a switch to flash some when a new device is plugged in. Of course, things should normally settle down within a few seconds.
First question. Are you hooking up both ethernet connections? If so, don't do this as that will cause problems unless you are using managed switches and configure the links properly on both ends. The behavior you describe would be consistent with creating a loop in the network like this.
Assuming the above is not the case and you still have a problem, you'll need to snoop into the network a bit to find the cause of what's going on. Since the network is being locked out by this it's almost certainly some bad broadcast traffic which is hitting all ports. The good news is that if that is the case it's pretty easy to capture.
Go to www.wireshark.org and download wireshark. It's free and pretty easy to use. Load it on any computer attached to the switch and experiment around a bit with starting captures and sorting through the packets to get an idea of what normal traffic on your network looks like.
After this, plug the offending computer in and see what happens. The problem packets will probably be very obvious although what they mean or how to fix things might not be so obvious. If this is the case, just post what you find and we'll take it from there.
Good luck and let me know if you run into any problems.
Was this helpful?
Yes
No
Popular Solutions for E-Machines T3065 PC Desktop
Questions and Unsolved Problems for E-Machines T3065 PC Desktop
Do you recommend E-Machines T3065 PC Desktop?
Answer
Answer
connect to gnutella network
Answer
gnutella network
Answer
half of the screen has the start up and the other half is the desktop icons
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
skype calls break up after couple minutes. While I can still hear the person I am calling, he only... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For E-Machines T3065 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
