Question about Kenmore Dryers
Dryer will not cut off after setting dry time. what do i do
    President:
  • 1,723 Answers
The timer motor or timed contacts have failed. Must replace the timer unit for your model.
Posted on Jul 15, 2009
Clothes Dryer not drying properly
I had the same issue with mine and it turned out to be timer went bad. When I set it for an hour the timer was too fast and cut off after 15 minutes. Replaced the timer and works fine.
Nov 06, 2015 | Roper Dryers
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
It doesnt seem to dry very well or takes a really long time
Zannusi Dryer TDS383W element gets Hot (glows)then cuts out after few seconds then if I wait for couple minutes and reset the clock to any set time the element glows hot again until inbuilt thermostats 'click' again cutting out the element,this process is continuous with or without the lid and ducting in place.
Feb 14, 2014 | Zanussi TD4112W Electric Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
My dryer will not shut off when it is in the timed dry and there is also no heat for any of the different cycles.
If the dryer will not cut off in the timed dry , then the timer is bad . However , there can be no connection between not cutting off on timed setting AND no heat (unless the timer happened to burn up inside ) which would be unusual .
Jul 17, 2009 | Whirlpool Dryers
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Magic Chef Gas Dryer # YG225LV
VT,
The dryer is clogged disconnect the exhaust hose(usually a 3-4 inch thin spring like tube) from the back of the dryer and clean out the entire thing disconnect it from the window (I imagine this is what you have it connected through?) and make sure all lint is removed and then reattach. Also make sure you don't have to much slack going from the machine to the window. Cut any access hose off. It should go the shortest possible path no big loops or sags! After this it should heat up like you just pulled it out of the box.
BMG
Sep 20, 2008 | Magic Chef CYG2000AWW Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
