How do I turn down the volume on outgoing fax transmisions for a Konica 7022 Copier.
  • 145 Answers
To disable the speaker, perform the following:
1. Access the Key Operator Mode (press HELP, then touch Key Ope mode at the left front of touch screen and then enter Password if necessary).
2. Touch 2. FAX from the Key Operator Mode screen.
3. Touch Line Parameter Set from the Fax Initial Setting menu screen.
4. Use the UP and DOWN arrows to select Line Monitor Audio.
5. Touch EDIT to switch from ON to hear transmissions, or OFF based on customer demand.
good luck
Posted on Jul 16, 2009
  • sam gerban
    sam gerban Jul 16, 2009
    good luck
  • sam gerban
    good luck
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 - Need to change login password
Hello sir; Go to set up your own password then you can use it, hold down 2 & 5 while you turn power on, then pick up password set, follow the direction to finish,then turn power off.
Mar 30, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Error code F-35-6 on my konica 7022 copier
You could try to reset the code. F35-6 is a fuser code, either you have a power surge later or bad thermistor in the fuser unit. Power off your machine, while hold down 2 and 5 button power the machine, this should take you to the 25service mode. in the softswitch mode go to switch #3 turn bit 1,2 and 3 to 0. than power off and on your machine. if this doesn't work you need to replace your thermister and possibly the thermostat.
Sep 17, 2008 | Konica Minolta Minolta DI1610FP...
115 people viewed this question
jasbo
jasbo
