Question about JVC KD-SX650 CD Player
HOW DO I SET THE CLOCK - JVC KD-SX650 CD Player
  • 217 Answers
I've had two Pioneer CD players and they both were set the same way. Turn it off then press and hold the AUDIO button if it has one. Then keep pressing it until it gets to the clock. I think on mine the hour starts flashing. When your done just turn it back on. == Answer == I had this problem too. In the far right corner is the "A" (Audio) button. Turn the stereo off and hold the "A" button until the clock comes on. The hour will be blinking. Use the up and down "Select" keys to set that. Then use the right "Select" key to switch to the minutes. Use the up and down keys to set the minutes. Push the "A" button when you're done. My stereo is older than yours but this is what someone who has one like yours told me to try and it worked
Posted on Jul 15, 2009
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    I have a c218 and i can't set time
    Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
    Don't expect this clock to set the time by itself. It is not an atomic clock.
    Oct 06, 2012 | Sony Bedside Icf-c218 Automatic Time Set...
    Teac model LT-1 how to set clock
    To set time on TEAC CD Receiver LT1
    Press Memory/Clock Adjust button until numbers flash.
    First display is 24/12 for choice. Change with >>> button.
    Press Memory/Clock Adjust button again and Hours digit
    flashes. Set with >>> or <<<.
    Press Memory/Clock Adjust button again and Minute digit
    In 12 hour mode "PM" will be displayed
    Sep 23, 2012 | Teac LT-1 Clock Radio
    Setting clock
    Hello
    To set clock:
    1. Press "Timer/clock button". The hour digit begins to flash.
    2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
    3. Press SET button. The minute digits begins to flash.
    4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
    5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
    If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
    Jan 21, 2012 | JVC MX-D402T Shelf System
    How do you set the time on Brookstone iDesign Cube Clock Radio?
    Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done!
    Jul 05, 2010 | Brookstone (467522) Clock Radio
    Settiongs for Weather Data World Clock
    Citizen Weather Data Clock Settings.
    To set time press and hold for 5sec "set" button
    Use advance to add days, years, hours seconds.
    Press SET to hold.
    Oct 17, 2009 | Citizen Watches
    I cant set the clock on my pioneer deh 21001b cd player
    Adjusting initial settings
    1 Press SRC/OFF and hold until the unit
    turns off.
    2 Press MULTI-CONTROL and hold until
    CLOCK SET appears in the display.
    3 Turn MULTI-CONTROL to select one of
    the initial settings.
    CLOCK SET (clock)—AUX (auxiliary input)
    # To return to the previous display, press
    DISP/BACK/SCRL.
    # To return to the main menu, press and hold
    DISP/BACK/SCRL.
    # To cancel initial settings, press BAND/ESC.
    Setting the clock
    Use these instructions to set the clock.
    1 Use MULTI-CONTROL to select
    CLOCK SET in the initial setting menu.
    Refer to Adjusting initial settings on this page.
    2 Press MULTI-CONTROL to display the
    setting mode.
    3 Press MULTI-CONTROL to select the segment
    of the clock display you wish to set.
    Each time you press MULTI-CONTROL, one
    segment of the clock display is selected.
    Hour—Minute
    As you select segments of the clock display,
    the selected segment blinks.
    4 Turn MULTI-CONTROL to put a clock
    right.
    Sep 26, 2009 | Pioneer DEH-2100 CD Player
    How do I set the time on my Pioneer RT500?
    Hi!
    Please follow the instructions given below... =)
    Setting the clock
    The clock is set to the correct time automatically, but it
    can also be set manually. The clock can be set for
    daylight saving time and time zone.
    Preparation:
    • Turn ON the TV and set it to the video input mode.
    • Select “CLOCK” from “SYSTEM SETUP”. For the
    procedure, see steps 1 to 3 in “Using the SETUP
    MENU”
    1 Press SETUP while the DVD and video tape is
    stopped.
    The SETUP MENU screen will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    SETUP MENU
    ENTER/
    SELECT ENTER RETURN BACK SETUP END
    SELECT
    2 Press  or  to select the desired menu and
    press ENTER.
    The submenu screen of the selected menu will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    LANGUAGE
    PARENTAL
    CLOCK
    DISC SETUP
    OTHER
    SETUP MENU
    3 Press  or  to select the desired submenu and
    press ENTER.
    The screen for the selected submenu will appear.
    CLOCK (manually)
    You can manually set the date, year and present time
    with the remote control.
    Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
    1 Select “CLOCK” and press ENTER.
    01/01/04 12:00AM
    2 Select the desired items using  or  (month,
    date, year, hour, minute and AM/PM) then press
    ENTER.
    3 Press  or  to set the value of the selected
    item.
    • For the minutes, press  or  once to set the time
    minute by minute, or hold down either of buttons
    for several seconds to set the time in 10-minute
    intervals.
    10/30/04 10:200AM
    4 Repeat steps 2 and 3 to set the date, year and
    present time, and press ENTER. The SETUP MENU
    will close.
    This completes clock time setting.
    AUTO CLOCK
    You can automatically set the clock by turning “ON” the
    AUTO CLOCK function.
    When you want to set the auto clock function to “OFF”,
    select “AUTO CLOCK”, press ENTER and select “OFF”
    from the list.
    Auto clock setting
    Preparation:
    You must connect the antenna or cable before connecting
    the AC cord to the power source.
    Wait 30 minutes with the power turned off, after the
    antenna or cable is connected, for the auto clock
    feature to activate.
    After the clock is set automatically, you may have to set
    the time zone and daylight saving time. (See page 26.)
    Press STANDBY/ON to turn on the DVD/VCR after the
    auto clock operation completed.
    • When shipped from the factory, the “AUTO CLOCK”
    option is set to “ON” position.
    • If you turn the DVD/VCR on during auto clock
    setting, the clock is not set.
    • After a power failure or disconnection of the power
    plug, the clock setting will be lost. In this case, wait
    30 minutes before turning the DVD/VCR on.
    • With cable box connection, if the auto clock setting
    is unsuccessful, select the PBS channel carrying
    the XDS information, then turn the DVD/VCR off.
    After 30 minutes, turn the DVD/VCR on.
    • If the clock is not set automatically, set the clock
    manually.
    STANDARD TIME (Time zone)
    In the rare event that you live within the broadcast range
    of two stations in two different time zones, the DVD/VCR
    may recognize the wrong station for the auto clock set.
    To correct the situation:
    Select “STANDARD TIME” and select the time zone from
    the list below.
    Selectable time zones and correction times
    ATLANTIC: GMT – 4 hours
    (GMT: Greenwich Mean Time)
    EASTERN: GMT – 5 hours
    CENTRAL: GMT – 6 hours
    MOUNTAIN: GMT – 7 hours
    PACIFIC: GMT – 8 hours
    ALASKA: GMT – 9 hours
    HAWAII: GMT – 10 hours
    AUTOMATIC: AUTO SET
    Note
    • When shipped from the factory, the “TIME ZONE” is
    set to “AUTOMATIC”.
    • After making the auto clock setting, in some cases
    the clock may display another time zone. You can
    correct the clock by selecting your time zone
    setting above.
    • When the clock is not set or you set the clock
    manually, the time zone setting is not available.
    DAYLIGHT SAVING TIME
    You can set the clock to daylight saving time automatically
    or manually.
    To select daylight saving time, select “DAYLIGHT
    SAVING TIME” and select “ON”, while to cancel the
    daylight saving time, select “OFF”.
    ON: For manual setting (forward 1 hour)
    OFF: For manual setting (back 1 hour)
    AUTOMATIC: For automatic setting (read XDS in
    the signal)
    Note
    • When you want to set daylight saving time, on the
    first Sunday in April you set it to “ON”, and on the
    last Sunday in October you set it to “OFF”.
    • When shipped from the factory, the “DAYLIGHT
    SAVING TIME” option is set to “AUTOMATIC”.
    • When the clock is not set, the daylight saving time
    • When there is no daylight saving time in your area,
    always select “OFF”.
    Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
    GPX clock radio clock question
    I emailed the company and they sent a pdf of the manual back the same day.
    partsinfo@dpi-global.com
    Jun 06, 2008 | GPX CRCD6306DT Clock Radio
    Setting the time
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
    Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
    The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
    The third is just the brightness.
    Now, to set the time itself:
    1 - Turn the clock face back up to where you can see it.
    2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
    Good Luck!
    Mar 16, 2008 | RCA RP5420 Clock Radio
    JVC KD-SX650 CD Player Logo
    135 people viewed this question
    Top JVC Car Audio & Video Experts
    Radames Pagan
    Radames Pagan
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
