Question about Volkswagen Golf Vw Diecast Model
2001 seat ibiza radio/heater fan panel problem
Radio automatically turning itself on with key in and out of ignition which drained battery.and will not stay off. also a/c, heater fan controls do not respond when buttons are pressed. outside temp gauge reading 42*C in ireland!!! can this be fixed
  • Anonymous Mar 17, 2014
    seat ibiza radio how do I set the channels manually in my seat Ibiza copa 2012
Check the sensor in de right mirror. It will be wet and dirty
Posted on Sep 08, 2011
Hey my friend, I m having a problem with my seat ibiza, radio goes on automatically. How did you solve the problem. I would so so much appreciateif you could help me. reply on darrencush@gmail.com
thanks in advance
Posted on Oct 22, 2010
Seat ibiza faults
Check alternator charge rate and earth straps
Jun 19, 2014 | 2007 Seat Ibiza 1.2
Seat Ibiza (2003) Remote central locking failed. Car only lock and unlock with key,it is a second-hand car so I dont have another key to try. Anyone help, Thx
check the battery in the fob, replace it. then get in the car put key in the ignition and turn to number 2 press fob door should lock then press fob again to unlock then take key out and test again should be fine again then.
Mar 19, 2014 | Seat Ibiza Cars & Trucks
How can I tell if battery is bad or a short draining battery
Take the battery to an auto store. They have an amp meter to test it with. Check for poor connections at the back of the radio. If it's wired to a hot lead and not the ignition ( key on) or aux, my old cd player would turn itself on and run down the battery while parked. For me, bad radio.
Jan 04, 2013 | 2001 Chevrolet Astro
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
My seat ibiza radio keeps turning itself on and running the battery down
Simple solution for anyone! Had the same problem with radio turning itself on in my Seat Ibiza Stella 1.4 2000. Here's what you do..
. Remove front panel
. Disconnect tape player and open it
. Clean the mother board paths(bottom side) with some chemical liquid not to strong(i used sticker remover) from black dirt. You can scratch between paths with a needle for better effect.
. Put all back together
. Problem solved.
It was driving me mad but now it's working when I want it to :)
Jan 08, 2012 | Cars & Trucks
I have a 2001 ford expediton 4.6 4wd..2 days ago I went to turn off my car and the radio and that beeping sound when the key is in the ignition when the door is open stayed on and wouldnt go off. I turned...
Not the Key but the ignition itself. Replace teh ignition module where the key is inserted to start the vehicle and that should resolve the issue.
Jul 11, 2011 | 2001 Ford Expedition
I have a mark 3, Y reg seat ibiza 1.4s,with an array of wierd electical problems. the radio keeps turning itself on, even when the car's ignition is off, the keys out, and the doors locked. It flattened my...
Ive got the radio problem, having to remove the radio fuse each time I get out of the car - its the blue 15amp on the top row of the fuse board. As for fixing it, heard its either down to the radio switch or diode? Taking mine to garage though.
Jan 09, 2010 | 2001 Volkswagen Golf
When I turn off my ignition, my heater fan will keep running
I just started experiencing the same problem. Yes, typically after rainy days, I can never get the interior lights to go out after the ignition key has been removed. The car acts as if there is a door open. Now, my latest problem is with the heater fan. Of course, putting the control in the "off" position will turn it off but you can turn it on and off with no ignition key installed. I'm also having problems with my heater core too so it's been a pain in the but!!
I believe this problem has also caused my battery to die which is why I'm on this site in the first place!! I can't get into the car with the keys and the dead battery won't allow me to unlock the car!! When it rains it pours!!!
Sep 15, 2009 | 1998 Ford Expedition
I dont have the unlock code to my SEAT IBIZA car radio model 1999-2002. what should i do?
I have a SEAT Toledo, year 1999. The radio has been blocked ever since the battery was changes 6 weeks ago. I have the code but on the LED I see only "SAFE". The "PROG" button will not work. How can I unlock the radio and use it again?
Aug 19, 2009 | Volkswagen Car Audio & Video
Constant battery drain-ammeter in line under 2amps. pulled fuses from 3 boxes- no change? is there more than 3 f.boxes? pulled under seat computer cables- still drains. alternator diodes? strange crackling...
pull key out of ignition and wait 2 minutes for the can system to go to sleep(instrument cluster is off) and all doors are shut-no consumers on should be approx. 50 ma.
Jun 10, 2009 | 2001 Mercedes-Benz C-Class
Volkswagen Golf Vw Diecast Model Logo
2,256 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
