Question about Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White
We are installing a Tara 8450, and may need to eliminate the tile surround in corner. Is there a trim kit available? Thank you.
  • 297 Answers
I have not seen a trim kit for this application.you may have to rework the corner with tile.chaulk is your best friend.
Posted on Jul 30, 2009
Jacuzzi tara o ring
What is the o-ring used for? Where is this o-ring located and what is the function of the o-ring?
US Parts Center
Mar 09, 2014 | Jacuzzi Tara, Whirlpool Bath -...
For Danze Sheriton/Plymouth tub/shower faucet, I am finishing the wall with ceramic tile and have set plumbing so plastic guard face will be flush with finished tile. One drawing in the instructions shows...
Don't cover area where plastic guard should be. Make it flush. Some trim is designed to recess into the wall before it's flush. Screws, adapters, trim etc. all will need to be installed when tile is set. Make sure you have nipples extending out from shower head and spout area's as well. If you do this and think ahead a little, you will have fewer problems assembling trim.
Apr 23, 2011 | Danze & Single Handle Tub And Shower...
Our tub has a lip around the top of 3 sides. The tub was either set in a little crooked or the wall is crooked. The inside corner on the faucet end of the tub the concrete wallboard is recessed about 1/8...
  1. 1
    Cut the tip off the tube of caulk, and load the fresh tube into the caulking gun. Puncture the seal inside the tip of the tube using a nail, stiff wire or the special puncturing tool built onto many caulk guns.
  2. 2
    Insert backer rod into large openings. These foam strips are available in sizes ranging from 3/8 inch to over 1 inch, and should be perfect for most bathroom filler needs. For larger holes, consider using a foam spray filler, but be careful as the foam expands a great deal and could overflow onto your work area if too much is used.
  3. 3
    Caulk the joints as you normally would. For large cracks, don't force your caulking into the crevice, but simply form a bead over the crack. Use multiple beads and a caulking tool or piece of scrap lumber to shape the caulk and remove excess.
  4. 4
    Allow the caulk to dry for 4 to 6 hours. Using the tip of your utility knife, check that the caulk adhered to all edges and formed a seal. For really large cracks, it may be necessary to repeat the process.
  5. 5
    When caulking open cracks, place a bead along each edge of the crack. Allow the caulk to set for 5 minutes, and apply a third bead over the first two. Use the damp sponge to shape and remove excess caulk.
Feb 04, 2011 | Home
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    My GE monogram has white panels, and I want to change them to stainless steel. Where can I buy them, and do I need a special trim kit? Thank you!
    The model number that you referenced appears to be a stainless steel model. I know of no trim kits available.
    Some of the older models did have door trim kits available.
    Model PSS26MSRSS should be a stainless steel model unless this is the wrong number.
    You can call the GE answer center at 800-626-2000 and get the information you need.
    Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Replaced trim ring and handle, now hot is cold ,cold is hot
    Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
    Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
    Install a inline hot water heater what make and model
    any heater will work. find one that is easy to install. Here is a link to someone who sells these. Bath Heaters
    Nov 14, 2009 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
    Cutting resin tile
    You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
    Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
    No access panel and need to reconnect the vacuum hose
    The trip lever is an over flow for the tub to prevent you from over filling the tub capasity and flooding your home.
    Mark
    Dec 24, 2008 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
    TRIM KIT INSTALL
    Phone these guys at maytag - sorry info is not available online 1-800-688-9900. Hope this helps :)
    Mar 09, 2007 | Maytag MMC5000 Microwave Oven
    Jacuzzi 8450-959 Tara Whirlpool Bath 5'- White Logo
    131 people viewed this question
    Top Jacuzzi Home Experts
    Mike
    john h
    Donni Steen
    Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
