Question about Sony CLIE PEG-T615C Handheld
Hot sync my sony clie peg t-615c will not do a hot sync with iMac computer. It has worked previously. I tried a hard reset on the hand held. When it worked it would sync with handspring selected, not clie, which I thought was odd but as lon as it worked, fine with me. jmorgan123 suggested I reinstall the drivers on my computer. I trashed the 'Myssing Sync' folder and reinstalled missing sync using the original CD I purchased from Still does not work. I would like to connect with jmorgan123 but as yet have not found how to recontact him Thanks, Sprinklerdan
  • sprinklerdan Nov 17, 2007
    cradle/cable connection
    HotSync v4.0
    local setup under serial port settings
    OS 9 is used for palm pilot desktop--which I have running when Hotsync is tried
  • 111 Answers
What connection are you currently using for the sync? and which version of the os are you using?
Posted on Nov 17, 2007
  • 1 more comment
  • Trinity Sabre
    Trinity Sabre Nov 17, 2007
    sorry, i meant the mac system version.
  • Trinity Sabre
    welp, regardless of the version, here's the best advice i can give you on troubleshooting it for right now.
    try using the palm desktop software first,
    get the version for palm, tungsten, and zire
    they have multiple versions for multiple system revisions
    if this does not work, then try the following
    Go to: /Applications/Utilities/ and run 'System Profiler' and find the
    USB port. This is where you will look to see if the device is seen by
    the Mac.
    2. Check the device and be sure it is is securely in the
    cradle or securely connected to the cable. Also make sure that the USB
    cable is plugged directly into the Mac and not into a hub or keyboard.
    Check you connections. There is the section called 'Connections'. It
    will have three icons, a USB connector, a globe, and a Bluetooth icon.
    If one of these connections is available the icon will have a blue halo
    around it. If it is NOT active it will be gray. Please make sure that
    the USB icon is blue.
    4. Launch a sync.
    5. Immediatly after
    starting the sync, refresh the System Profiler by using the key stroke
    combination (Apple + 'r') ...and then keep refreshing the profiler
    until the device shows up on the bus, or until the device times out
    if it finds the device
    to 'System Preferences' on your Mac and then go into 'Accounts'. Look
    at the 'Login Items' tab. You need to check for 'Transport Monitor' or
    'Palm Desktop Background', if you have either of them, then you must delete them
    from the list, not just uncheck.
    1. Click on the blue Apple menu (top left hand corner)
    2. Select System Preferences
    3. Select the Accounts icon
    4. Choose the "login items" tab
    this point you will be able to see if you have the "Transport Monitor"
    or the "Palm Desktop Background" listed. For Missing Sync to recognize
    the device you need to have Missing Sync Monitor installed in this list.
    One other thing that can prevent Missing Sync from seeing a USB
    connection, and that is a conflict with an iTunes Plug-in from
    if it doesn't find the device
    can try repairing the permissions. On your Mac, go to
    /Applications/Utilities/ and run Disk Utility. Choose the disk in
    question and then click on the Repair Permissions button.
    After doing the step above try the test again.
    another issue may be dirty connections on the sync cradle or one the clie itself, you can use a q-tip and a contact cleaner/rejuvinator like rid-ox or de-oxit to clean the connections.
    let me know what happens, if it doesn't work i will see what else i can do.
  • Trinity Sabre
    and as far as the palm desktop software goes, try using version 2.6.3 as well, as some of the newer versions seem to have an issue with avantgo.
My Toshiba with Vista wont install the driver hot sync driver can not hot sync
Try the offiacial toshiba site,,,,,drivers on there,,,good luck
Dec 19, 2011 | Sony CLIE PEG-S360 Handheld
Sony clie pegt-615c
Try re-installing the drivers on your computer.
Nov 04, 2007 | Sony CLIE PEG-T615C Handheld
Hotsync Problem with Sony Clie PEG-T615C using XP SP3
Maybe you could also try updating Palm Desktop or maybe downgrading Palm Desktop because I have that exact same PDA and I know it's old. If neither of those work, just pull a system restore or whatever you had planned.
Dec 23, 2009 | Sony CLIE PEG-T615C Handheld
I have a Clie SJ22/U and downloaded the Vista driver, but it still won't hot sync can you help?
I have a peg-615c, and I just downloaded the new palm desktop, and installed it AFTER I had switched the compatability mode to xp, and selected open as an admin on the normal screen, and under all users...
I works great now! OH, it's a free program :)
Jul 04, 2009 | Sony CLIE PEG-T615C Handheld
I can't get the Clie PEG-SJ20 software loaded on my computer
 Word is out that OS 6.01 can be installed for SJ20 to work sync in Vista even though Sony hasn't listed it as compatible.
Dec 31, 2008 | Sony CLIE PEG-SJ20 Handheld
Sony Clie PEG-N760C hot sync with Windows Vista
I had the same problems. I downloaded PalmDesktop Win62.exe update from and it recognized my USB connection, did away with the port error and hotsynced immediately. I messed with that thing for 3 weeks before I finally tried the update. It says it's not for the peg-n760c, but it works! I don't think they want you to update, but rather buy a new pda. Good luck!
Jan 25, 2008 | Sony CLIE PEG-N760C Handheld
Sony CLIE PEG-N760C Handheld problems with connection windows vista
No. I don't thiok so.
To connect with windows, the first step you have to intstaled Palm. OS. 4.1. It's the operating sistem to operate your clie palm. I've perobelm laki this before, but it solved.
thk u..
Nov 19, 2007 | Sony CLIE PEG-N760C Handheld
Help! My Clie Won't Work!
I had that happen last week. Just let it dry out and when the display started jumping, I did a HARD reset. Synced and it's now working like a champ. (Mine had a lot of moisture in it but did not have total emersion in water.) Good luck.
Oct 06, 2007 | Sony CLIE PEG-T665C Handheld
Hot sync problems
Doe's some one out there have the software that came with the sony clie peg sj22/u
software version 1.1
Sep 26, 2007 | Sony CLIE PEG-SJ22 Handheld
Sony CLIE PEG-T615C Handheld Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
