Question about Kitchen Appliances - Others
The turning mechanism on the bottom of the bread pan is frozen and will not turn.
  • 433 Answers
The bearing that turns the blade is frozen. Try soaking it in hot soapy water for a while. Then try to move it by hand. Try this a few times. If no luck, then you need a new bread pan
Hank
Posted on Aug 07, 2009
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
The gears underneath are frozen and won't turn the paddle inside the pan. Is there anyway to unfreeze the gears. It appears that the gear grease has all oozed out and the gears underneath are fused and...
The gear grease you are referring to is from the sealed bearing on the bottom of the pan. This has failed and will not allow the paddle to rotate. There is no replacement parts, and a new bread pan is needed. Sorry..Hank.
Jun 10, 2010 | Toastmaster TBR15 Bread Maker
The mixing blade will not turn. I have had difficulty with it for quite some time. I can no longer lubricate it so that it will mix the ingredients.
Take the bread pan out of the machine and see if you can rotate the paddle by hand. If you can't then the sealed bearing on the bottom of the pan is frozen and you need a new bread pan. If it turns freely keep the pan out of the machine and start a kneading cycle. Look through the lid window to see if the motor shaft is turning. If not, the belt has slipped off the pulley or it has snapped. Hank
Mar 01, 2010 | Zojirushi Kitchen Appliances - Others
The axis in the bottom of the pan, which holds the paddle, won't turn. The axis in bottom of the machine does seem to rotate when I try it without the pan. Is there a way to fix the pan?
Try putting warm water in the pan and let it soak. Try it a few times. If you can't turn the paddle by hand, then the sealed bearing that turns the paddle is frozen and can't be repaired. Sorry Hank
Feb 16, 2010 | Oster 5834 ExpressBake Bread Maker
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
Machine on but nothing happening
It could be two things that has happened. The easy fix is that the belt has fallen off the pulley and not turning the paddle or the belt itself is snapped. Secondly, it could be that the sealed bearing in the bottom of the bread pan is frozen. See if you can spin the paddle by hand. If no..then it's frozen. (try putting hot water in the pan to see if it frees up. If after a few tries it does not then the bread pan needs to be replaced). The motor and pulley assembly is located inside the base of the machine.
Feb 01, 2010 | Breadman TR850 Plus Bread Maker
Black and Decker B2300 Bread Maker - one of the 2 agitators quit turning. What is wrong?
HI,
It could be the sealed bearing on the bottom of the bread pan is stuck or frozen, or the belt fell off the pulley or has snapped. Hank
Jan 28, 2010 | Black & Decker B2300 Bread Machine
Bread machine, mechanical problem (American Harvester Classic)
Let's try a few things. First take the bread pan out of the machine and see if you can spin the paddle freely by hand. If you can't, then the sealed bearing in the bottom of the bread pan is frozen and the paddle won't spin during the kneading cycle. Try putting hot water in the pan and let it soak. Try this a few times...If that does not work you will need a new bread pan. If everything is good with the bread pans, then take both pans out of the machine and start a kneading cycle. Look through the top window (if you have one) and see if the motor shafts are spinning. If not, then the belt fell off the pulleys, or has snapped, or the motor is broken. Good Luck..Hank
Jan 17, 2010 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
41 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
