Question about Yamaha 12V Air Pump
1998 GP1200 yamaha jet ski won't start
I have a 1998 yamaha GP1200 jetski, I am not getting a spark to the engine. I have replaced spark plugs and wire and still the same problem.
    Problem Solver:
  • 5 Answers
When replacing battery in yamaha GP1200 when attach negative cable the unit seems as wants to turn over the engine while the unit is off and no key in place.. also notice in seconds that the battery terminal on negative side started smoking..actually melt the new battery terminal on negative side..yes, postive was connected to positive. Any ideas what why this would take place??
Posted on Aug 16, 2009
    New Friend:
  • 3 Answers
That means you have a direct short somewhere bad start solenoid or shorted feild windings in starter.
Posted on Jun 07, 2013
I have a starting problem with my 2005 Yamaha XTL 1200 jetski it turns over but won’t start I took out the spark plugs and cleaned them they were black but still wouldn’t go
Black plugs indicate carbon build up. Try starting with ether sprayed into carburetor. If it fires, clean fuel system with spray and additive. Use the fuel engine was designed for.
Jan 11, 2018 | Yamaha Jet Ski Pwc Watercraft Cover Wave...
What is the yamaha spark gap for jet ski engines 1990 year
0.024
http://www.globaldenso.com/cgi-bin/global/plug/usa/pw/pw-plug.cgi?filename=pw-14.txt
Sep 01, 2014 | Clymer Yahama 2-250 HP Two-Stroke Outboard...
Jet ski wont start
does it have spark at plugs ? carb clean and fuel new ?
Jul 22, 2014 | WSM 1997-1998 Yamaha Wave Runner 760 Cc...
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
I have a yam gp1200 jet ski 1998 which i bought as a non runer. I have just had the engine repaired and wondered if i will need a code to start it. I was not given any codes when i bought it....Many thanks...
Yes you will need the code to start. click on this link it should take you to the Yamaha website so you can download the owners manual. it will show you how to reprogram the GP1200 start. yamaha-motors.com
Oct 27, 2009 | Boating
2001 sts 900 kawasaki jetski wont start
Check the engine compression with a compression tester. It should be over 100psi,also check for hot blue spark on plugs,if not blue ignition problem.Weak Spark,but if blue and wont fire with ether the rings maybe worn,and compression to low...Best of luck to you!!!!
Aug 09, 2009 | Boating
Yamaha 12V Air Pump Logo
2,268 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
