Question about Toro Lawn Mower With Toro Power Tools
Toro lawn and garden tractor will not start all of the stafety switches are working and the battery is charged but the safety relay will not energize.
    President:
  • 1,129 Answers
Remove the two wires going to the switch and use a jumper wire to bybass the safety switch if it starts replace the switch, make sure power is getting to the relay, relays have two power wires one that activates the relay coming from the physically activated safety switch the other is a power wire that is activated by the ignition switch, you must have power to the relay with ignition key on.
Posted on Jul 15, 2009
Wont start no power to switch
I'm not familiar with your brand and make of lawn tractor but here's a few basics many of them have in common.
Any one of several safety features on newer lawn tractors will prevent it from starting.
Assuming your battery is fully charged, here's a few basic things to check, depending upon your level of skill and motivation:
1. Parking brake: A switch must be engaged when the parking brake is set. Most newer lawn tractors have to have the brake set to allow the starter interlock relay to energize the starter.
2. Blade engagement PTO: The blade PTO switch or lever must be OFF or the tractor starter won't energize.
3. Seat switch: Some (not all) newer lawn tractors won't start if the operator presence seat switch is not closed. (you have to be sitting in the seat or the starter will not be energized.)
4.. Corroded/loose battery terminals or wires. Remove the battery leads and clean the terminals. Check and make certain the battery leads are tight.
You can do some investigative sleuthing by using a multimeter, set in the OHM position, to test switch continuity. Locate and unplug these switches from the wiring harness, one at a time. Insert the meter's test leads into the switch plug's terminals; not the wiring harness. Activate the switch. If your meter shows current pass-through or continuity, the switch is working. If the meter reads OL (for digital meters) or stays at zero, that switch is bad.
If your safety switches are good, you'll have to look deeper.
Some lawn tractors have a fuse panel to protect the electrical circuits and components.
1. If you have a fuse block on your tractor, remove the plastic cover. Most of the fuses in today's tractors are the color coded, plastic cased, automotive type. Remove each fuse and inspect their filaments one at a time. A blown fuse will be easily identified. Replace any blown fuse.
2. The starter interlock relay may be faulty, or have a disconnected/broken wire. Check your wires and terminals. The starter switch itself may be faulty. Use your meter in the OHM setting, put your leads on the starter switch terminals with the switch disconnected and off. Turn on the ignition switch and turn the switch to the start position. If the switch shows current pass-through, the switch is good. If not, replace it.
3. Is your battery discharged? Do you hear a "click" when you try to start your tractor? If you hear a "click" when you turn your key to the start position, and your battery is charged, there's a strong likelihood your starter has malfunctioned and needs to be replaced. (or your engine is seized) If you hear absolutely nothing while trying to crank over the engine, it's a safe bet you're not getting power to the starter because of a safety switch, bad fuse, starter interlock relay, or a broken/disconnected wire somewhere.
Sep 20, 2015 | Cub Cadet LTX 1042 KW 42" 18HP Kawasaki...
Looking for the location of the clutch safety switch on an older toro commercial 11-32
Anytime your engaging blades it pulls quite a bit of juice from the battery, so you need to be absolutely sure your battery is good.
Jul 26, 2014 | Toro Garden
Switch wont start engine on 34 zturn mower model 74408
check for a blown fuse in the starting circuit and check all the safety switches there will be one under the drivers seat. Is your battery charged and are the connections clean and tight
Apr 27, 2014 | Toro Garden
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
Toro lawn tractor starting problem
both of the small wires to the solenoid go threw safety switches start with the one on the clutch/brake pedal
Jun 09, 2012 | Garden
Is there a fuse on my bob villa 21 hp craftsman lawn tractor? The battery is charged but it won't start, won't even turn over.
Check you safety switches, brake, neutral, seat, blades, and reverse (if equiped). Then if that does not work I check the starting solinoid and the ignition switch.
Aug 08, 2011 | Garden
Key start on lawn mower does not work
Check your starter fuse..follow ignition wire to starter..there is a fusable link inline. make sure u have power all throughh line to starter. :)
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Lawn Mower With Toro Power Tools Logo
490 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
