Question about Vizio L32 32 in. LCD HDTV
Stand by lcd stays amber, no power
Stand by lcd stays amber, nothing happens at push of power on button.
  • 24 Answers
I had the same problem until I saw a post tonight and tried it and it worked.The amber light would stay on and the power button did nothing.Locate U26 on your main board,it's a tiny smd IC chip.Heat up all the legs at once and drag it off the pad,then solder a 10K resistor on the 2 bottom pads where the chip was each leg of the resistor will be across from each other.I bought a main board week ago and had the same problem.I tried this on my old board and it worked,so I bought a bad board.Just because you pay good money for a board doesen't mean it can't be bad.Hope this helps.Very hard to solder in such a tiny space.
Posted on Jun 18, 2013
I need to register my 47" vizio tv
Posted on Jul 17, 2009
Blinking amber light
power board problem
Mar 19, 2015 | Televison & Video
Acer at3201w when i plug it in the amber standby light comes on. when i push the power button, the light turns green but nothing else happens. a few moments later it turns amber again and then goes off...
It may have gone into safety shutdown because it sensed short circuits in the power supply or in the backlight inverter board, you will have to look inside. Please read my guide to understand what the TV needs to operate.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 02, 2010 | Acer AT3705-MGW 37 in. LCD Television
Power button problem
i think that the power cable went fastly try replacing it
Jun 07, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
May 11, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Monitor
OPEN MONITOR , look inside the PC BOARD around the transformer area and look for a burnt solder or cold solder , re solder it , and try again , please rate solution , thanks AJ
Apr 28, 2008 | Acer AL2216W LCD Monitor
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio L32 32 in. LCD HDTV Logo
313 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
