Question about Panasonic TX-32PK1 TV
Picture wnet from normal while watching to just a thin line accross the middle
    Problem Solver:
  • 17 Answers
Be prepared to fight if you dare to cross that line
Posted on Jul 15, 2009
LG DR4810 black and white lines at top left and side of Picture extending accross middle of picture window. How Do I remove these?
I think you should take it back, cause! defective laser pickup, or the video processor, and possibly the audio/video cable, "replace to be sure"
May 08, 2012 | LG DR-4810 DVD Recorder
No picture
Must know how to solders?Cold solders or dead vertical IC must resolder or replaced the IC.Bang on the tv frame if the vertical get back to normal,it cold colders.
Jan 24, 2010 | Televison & Video
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Have an 18 YO RCA 19 inch set and all I get for a picture is a thin line accross the middle of the set. Have sound
Vertical IC,Bad capacitors,shorted yoke, get vertical Kit. 100uf 35v, 2.2uf 50v, 1uf 50v,
Jun 11, 2009 | Televison & Video
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
Verticle hold transistor?
The vertical hold keeps a normal picture from rolling either up or down. You don't have a normal picture (raster) here.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace.
Good Luck!
- Jim
Jan 24, 2008 | Televison & Video
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic TV - no picture, but sound is ok
it is due to vertical section failure.
  • before you start any work reduce brightness to avoid crt burn.
  • please check some loose contact or loose connector.
  • check supply to vertical section
  • check parts in vertical output section
  • check vertical ic.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Panasonic TX-32PK1 TV Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
