Question about Maxon MCB-30 40-Channels Base CB Radio
Wiring Three wires.. Red, Orange, Black. What needs to go where in the fuse box to give me continuous power. Thanks , Mike.
  • dacondon May 14, 2008
    need to know where the wires go
    Problem Solver:
  • 5 Answers
The orange goes to a fuse that is always on. That's how it remembers things when it is powered down.Like the clock on a Car stereo.
Posted on Mar 11, 2008
Twist red and orange together and hook to power then put the black to ground
Posted on Nov 22, 2007
Midland 77-118. Three wires coming out of unit red,black,and orange. What is the orange for? Also need manual.
Its like the wiring in your house. That little three prong plug. There are three wires, one black,one white, and one green. The green is a ground wire , the black is neg flow and the white is positive flow. Well the red wire is hot ,the yellow wire is neg flow,and the black is ground. Some times the yellow wire isn't even connected. Look inside your radio and you will only see a red and black wire???you will have to google the radio model as such ( 77-118 owners manual)
Sep 01, 2015 | Midland Radio Communications
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
I have replaced the cooling sensor with 2 wires on my 1999 ford tauras dohc and the fans still dont come on...can someone help me out on what else to check?
89b004a0-3483-43bf-8c74-29d0d7af8fa7.jpgI'm not sure what your reason was to change out the temp sensor but guessing some diagnosing should be done before you were to purchase more parts that aren't needed. To start with have you even checked the fuse for the cooling fans. In the picture above is the layout of the fuses & Relays in the fuse panel under the hood of the vehicle. I marked the fuse that needs to be checked with a red arrow and the yellow arrow is the low speed cooling fan relay location. There is some testing in order to check that but if the fans are not working on any speed then I doubt it's a relay issue. With the A/C on or the engine hot enough, you can check the red wire with the orange stripe or the red wire with the gray stripe. Using a test light you should have power in one of those wires. The red/gray wire is power for high speed and the red/orange wire is for low speed. If no power there then you are dealing with a wiring issue. I seem to recall but would have to look but I believe that year taurus had a main box to operate the cooling fans mounted to the crossmember just in front of the radiator. I think it was a black box with a number of wires at the connector to it. In any case check your fuse if you haven't chack your ground at the fan motors (the black wire) and check for power. If no power and ground is good as well as the fuse, you can reply here or email me directly at csautomotivecars@att.net and I can give you some other testing procedures to help diagnose it. Hope this helped....
Jun 05, 2013 | Cars & Trucks
Fitting SPY 5000m Alarm Suzuki Bandit 1200 NOT WORKING
wiring diagram would be helpful if theres a link, have you taken the ignition power source from before or after the switch. i.e does this need a live continual power or just on power.
Mar 10, 2013 | Motorcycles
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
Have a wiring harness for a CQ-C8100U panasonic CD Player/Head Unit, need a wiring diagram to hook it up to a 2002 Ford Explorer Sport 2 Door
Hello! Since I do not know if your vehicle is equipped with the Standard or Premium System I'll give both sets of wiring...You can identify which system you have by looking at the color of the ground wire...
Red=Standard and Black/Green =Premium
Standard...Constant +12=Green/Yellow...
Switched=Yellow/Black...Ground=Red...
Illumination=Blue/Red...
Standard Speaker
FR + White
FR - Green/Orange
FL + Orange/Green
FL - Light Blue/White
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Premium...Only power difference is Ground=Black/Green
Premium Speaker
FR+ White/Red
FR- Brown
FL+ Green
FL- White/Orange
RR+ Purple/White
RR- Blue
RL+ Blue/Black
RL- Yellow
Guru.....saailer
Feb 18, 2010 | Panasonic CQ-C8100U CD Player
Radio works just have no digital read out on 1999 explorer. Is it fused related?
Hello! Yes It could be fuse related. You have lost power on the Blue/Red lead, which is illumination to the radio.
If you have a multimeter you can look for +12volts on this wire with the key on. If it is not present; Check fuse #27 15amp inside drivers side fuse box.
In case you ever need the entire wiring; Here it is...
Green/Yellow memory +12volts with key off
Yellow/Black ignition +12volts with key on
Red Ground
Blue/Red +12volts with key on
SPEAKERS
FR + White
FR - Green/Orange
FL + Orange/Green
RR + Orange/Red
RR - Black/White
RL + Pink/Green
RL - Pink/Blue
Guru...................saailer
Jan 12, 2010 | Bose Car Audio & Video
Power Door Locks don't work
driver's door module should have a 12v battery feed..if this missing it could explain your problem..module not being powered up..look between driver's door and body..in harness,you may have broken wiring
Apr 25, 2009 | Jeep Cherokee Cars & Trucks
WIRING INSTRUCTIONS
Red=Positive 12v(switched)
Black=Negative ground
Yellow=Constant Power(Battery or fuse box W/ Constant power)
Grey=Right front+
Grey/Black=Right front-
Purple=Right rear+
Purple/Black=Right rear-
Green=Left rear+
Green/Black=Left rear-
White=Left front+
White/Black=Left front-
Blue=Amp turn on
Blue/White=Power antenna
Orange/White=Dimmer
May 29, 2008 | Pioneer Car Audio & Video
Maxon MCB-30 40-Channels Base CB Radio Logo
163 people viewed this question
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
