Question about Whirlpool Accubake SF362LXTS Kitchen Range
Whirpool gas range - propane gas not sure oven is working right
When we first got stove flames were yellow and we got lots of sooty fumes.
we adjusted the oven bake burner and regulator and it is better - but flames are still partly yellow at 350. At 400 it is like a blast furnace.
Also - should the gas cycle on and off during a a bake cycle?
Finally should we smell some gas each time the gas cycles on again during a bake cycle?
    President:
  • 704 Answers
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Posted on Jul 30, 2009
I had issues with my whirlpool oven and found out it was set to propane(per whirlpool) They aren't taking the blame for it but I bet you may have a similiar issue. It is also emmiting carbon Monoxide which can kill you. Call an independent appliance repairman to evalutate the stove.
Posted on Apr 13, 2010
I need 4 knobs for gas range model akg906/01
Serie N° 149610022602
Posted on Dec 31, 2009
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
We use propane gas. At first it had lots of flames and sooty smoke. We have adjusted the Regulator and the Oven Bake Burner as much as possible but it still has yellow flames like a blast furnce. What can...
The yellow flames is a sign of poor combustion which can release carbon monoxide. It sounds very much like the range was supplied with jets intended for natural gas which operates at lower delivery pressures.
You need to ensure that the range is usable in its current condition can be used with propane. Labels on the range (generally in back) should carry warnings about the proper gas and pressures.
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Change over to LP on whirlpool oven
All ovens come from the factory set up for natural gas. To convert to liquip propane you must change the orifices. Once you have the proper orifices, you will be able to make the adjustment you desire. You can contact your lp supplier and have them send their techie out as they do this as a free service.
Apr 07, 2009 | Kitchen Ranges
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
Feb 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
Jul 18, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Whirlpool Accubake SF362LXTS Kitchen Range Logo
1,000 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
